Yard Man - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-29-2015, 04:43 PM Thread Starter
BWC
Thanks (Received): 8
Likes (Received): 9
Yard Man
My neighbour's MTD Yard Man 10.5 hp Model #31AE9B3H501 lost auger operation the other day. The auger cable is broken up front where the auger and drive belts are. Unlike most, the auger cable is routed inside the blower and not on the outside. Will we have to split the blower to re and re a new cable? How else can you get this cable out and replaced? Tks. According to MTD this blower was made in October 2002.
1991 HS 8/28TAS
2016 HSS 13/32 ACT
2001 JD 455 / 47" front mounted blower
BWC is offline
post #2 of 7 Old 12-29-2015, 08:22 PM
Normex's Avatar
Likes (Received): 82
I'm not sure if this will help but see if it is compatible with your friend's Blower. Good Luck
http://service.mtdproducts.com/Train...0-600_Snow.pdf
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 7 Old 12-29-2015, 09:10 PM
Likes (Received): 280
^^ I think most of the newer ones are about the same as that. You should be able to do it without splitting the bucket and just remove the lower cover I think?
post #4 of 7 Old 12-30-2015, 07:15 AM Thread Starter
BWC
Likes (Received): 9
Thanks for that attachment. I will print it off and take it over when we tackle this in the New Year. Happy New Year
1991 HS 8/28TAS
2016 HSS 13/32 ACT
BWC is offline
post #5 of 7 Old 01-06-2016, 08:24 AM Thread Starter
BWC
Likes (Received): 9
Just an update. The auger drive cable was not hard at all to replace even though it runs through the transmission area. Decided to split it anyhow to check the impeller bearing and replace both belts. It is now back in operation.
Tks
1991 HS 8/28TAS
2016 HSS 13/32 ACT
BWC is offline
Thanks Kiss4aFrog, bwdbrn1 thanked for this post
post #6 of 7 Old 01-06-2016, 08:34 AM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4246
Likes (Received): 1676
Good to know you have it back together
post #7 of 7 Old 01-06-2016, 08:56 AM
Thanks (Received): 238
Likes (Received): 606
Glad to hear it all went well. Always love a story with a happy ending.
