HMSK80 with no spark - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 12-16-2013, 11:43 PM Thread Starter
Ok, so I was not getting any spark, so I read the Tecumseh manual and followed the instruction to remove the blower housing to lift the kill wire off the ignition coil.
I did that, replaced the housing and now I get reliable blue sparking. So that means my coil is good, but what do I check next? I don't think this unit has a low oil shutdown, at least not that I can find. The plastic key is in position so its not that. What other cut offs are there that I need to be checking?
Unit is a Tecumseh HMSK80-155545U
Any help is appreciated.
SteveM is offline
post #2 of 2 Old 12-17-2013, 12:02 AM
Thanks (Given): 572
Thanks (Received): 747
Likes (Given): 4237
Likes (Received): 1657
Follow the wire and see if it's nicked and shorting to ground against the engine at some point. Some also have a second wire leading to the throttle so you can shut it off with the throttle by grounding that same wire.
