MTD with Tecumseh 5hp - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 01-02-2014, 01:38 AM Thread Starter
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
I have a 12 year old Yard Machine - MTD with a 5 HP Techumseh Snow King.
I was running it tonight and noticed the exhaust was slightly glowing red.
I rarely run it in the dark and it may have always done this and I just can't notice it in the day light.
It does not have an adjustable carb. I replaced the carb last year and it starts easy with the pull chord. I don't think it is running too lean.
Exhaust valve may be a bit worn. I looked at it last year and it was pretty good. The valve stem guide was worn a bit.
Is this normal for this engine and if not any ideas as to what may be going on.?
There is a compression release feature at start up that makes it hard if not impossible to get a compression test on this machine with a basic compression tester.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #2 of 2 Old 01-28-2014, 07:37 AM
iwlu25's Avatar
Troubleshooting
Can you locate & read the engine model# & specification label to help troubleshooting?
Google Drive Tecumseh Power Link
iwlu25 is offline
