Surging & Auger Issues - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 13 Old 12-22-2018, 08:06 PM
Thanks (Given): 92
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 421
There is a Murray belt 585417 but most take 585416. Right now I have several Murrays, 5, 8, 10hp, 2 Nomas 5 & 9hp, and a 8/26" Dynamark. They all take the 585416, 1/2" x 38" auger belt. For accurate belt length, I only buy D&D Power or Pix, prefer blue, and prefer Kevlar. Before you scrap the belt, measure the outside length.
post #12 of 13 Old 12-22-2018, 09:07 PM
orangputeh's Avatar
Thanks (Given): 704
Thanks (Received): 200
Likes (Given): 1222
Likes (Received): 1218
Originally Posted by JLawrence08648 View Post
If you have an adjustable screw on the bottom, through the fuel bowl, that is the high speed adjust that running at full throttle.
If you have an adjustable mixture screw on the side, that is the low speed. It should have a shooting on it with a rubber O ring and a small brass washer, same with the bottom mixture screw but they are not interchangeable.
Some Tecumseh carbs have a side jet, not a mixture screw. This is not adjustable. If you are unsure, unscrew it. If it's a needle valve, it's a mixture screw. If it's blunt at the end, it's a jet. The jet also has a smaller screw head than the mixture screw, and screws all the way in, flush. The mixture screw does not screw all the way in.
thanks. found a video from donyboy73 that shows the exact carb . almost have it dialed in. still working on proper idle.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #13 of 13 Old 12-23-2018, 01:25 AM
Likes (Received): 37
Keep in mind the mixture will be different if thereís are significant temperature change
Dial it in when your in the garage and itís warm then in the cold it doesnít run as well.
I find I pick up 100 rpm running in the cold.
Also I find the tecumseh 8-10 hp do not idle down as well as other single cylinder engines.
Red
bigredmf is online now
