Tecumseh HMSK105-159915C help - Page 3 - Snowblower Forum : Snow Blower Forums
post #21 of 62 Old 01-02-2018, 10:22 PM
deezlfan's Avatar
Likes (Received): 30
What did the rest of the stuff under the flywheel look like? Clean as the rest of the motor? Was thinking a rodent may have dragged some stuff up inside. Also did you shake the muffler after you took it off? Possible loose baffle.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
post #22 of 62 Old 01-02-2018, 10:29 PM
Likes (Received): 303
Wha
post #23 of 62 Old 01-02-2018, 10:35 PM Thread Starter
Likes (Received): 8
A few days ago I read that carbon build-up can create a really loud rapping sound due to the minimal space of these flat head engines. Has anyone ever heard of this, or experienced it first hand on their Tecumseh. I really don't know what else it could be.
mtblade is offline
post #24 of 62 Old 01-02-2018, 10:39 PM Thread Starter
Likes (Received): 8
Perfectly clean. No rodent problem. Yes, I did shake the muffler. Solid, no noise at all. On the tear down, all the nuts and bolts were tight. Not one was loose anywhere on the engine. I was hoping I would have found something loose. It would have been much easier.
mtblade is offline
post #25 of 62 Old 01-02-2018, 10:40 PM Thread Starter
Likes (Received): 8
Originally Posted by jtclays View Post
What's the starter gear look like?
All intact.
mtblade is offline
post #26 of 62 Old 01-02-2018, 11:00 PM
deezlfan's Avatar
No, not really. You would need a tremendous amount of carbon to cause a knock like you described and I see no evidence of it in your pictures.
deezlfan is offline
post #27 of 62 Old 01-02-2018, 11:46 PM Thread Starter
Likes (Received): 8
I'm going to clean everything up, order a gasket set, put it back together and see what happens. Thanks guys. I appreciate all the input.
mtblade is offline
post #28 of 62 Old 01-03-2018, 07:40 AM
Thanks (Given): 181
Thanks (Received): 164
Likes (Given): 1740
Likes (Received): 399
I'm intrigued by the oversized piston (0.010"). It would suggest rebuild but you've had it since new.
The governor gear marring hopefully came from assembly when they tried to mesh it with the cam gear.
before slapping it together, make sure the governor spool / weights still move freely and as-intended.
the same goes for the compression release...it's only supposed to bump the exhaust lifter at low-speed.
i don't know if it's an optical illusion but is the left-side of the main journal damaged?
classiccat is online now
post #29 of 62 Old 01-03-2018, 08:49 AM
Was
Name:	tecumseh block marks.PNG
Thanks classiccat thanked for this post
post #30 of 62 Old 01-03-2018, 09:16 AM
Thanks (Received): 28
Likes (Received): 41
What did you have for valve lash? I would check to see if a valve seat is loose. Did it rev right up to full rpm or just kind of chug when you tried to go full throttle?
351beno is offline
