Saving a Murray made Noma - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 04-15-2018, 01:36 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Thanks (Received): 76
Likes (Given): 222
Likes (Received): 175
This non-runner had been listed for a while for "$200 but open to offers" and its price was changed to free. I didn't respond to the ad right away because I thought for sure someone would have beaten me to it, but the guy responded right away stating it was available. I picked it up yesterday. It has the 8hp Snow King + 27" bucket.
It was very dirty but everything was intact.
The first thing I noticed when I pulled the carb cover off was that the primer bulb hose had rotted off right at the carb.
Once I cleaned the green stuff inside the carb and replaced the adjustable main jet (the old one had a crumbling o-ring), it started right up.
It needed some help:
1) one of the mounting holes on the plastic chute had broken off - i replaced the entire chute with a spare one from a Craftsman
2) the 2 springs that keep tension on the belts had fallen off and were lying in the belly pan
I'll probably throw some new skids on it and then add a headlight before listing for sale next season.
ID:	142770   Click image for larger version
db130 is online now
post #2 of 9 Old 04-15-2018, 02:14 PM
Thanks (Given): 95
Thanks (Received): 189
Likes (Given): 72
Likes (Received): 434
The Murray's have a problem with clogging of the rectangular exit chute coming off the impeller housing. I did a post on this couple of weeks ago with pictures increasing the size by making a semi circle exit. It does involve cutting and welding.
post #3 of 9 Old 04-15-2018, 03:02 PM
Likes (Received): 717
Not worth $200 not running, but definitely worth what you paid!
cranman is online now
post #4 of 9 Old 04-15-2018, 03:12 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 222
I forgot to mention this... but the thing had no handlebar grips!
I scavenged a set from an old Bolens (both the Bolens and the Noma have 1.25" tube diameter) using the "JimsTroyBilt method"
db130 is online now
post #5 of 9 Old 04-15-2018, 05:19 PM
KOBO's Avatar
Thanks (Given): 9
Thanks (Received): 8
Likes (Given): 43
Likes (Received): 35
Nice one, good score.
KOBO is offline
Thanks Fat City thanked for this post
Likes Fat City liked this post
post #6 of 9 Old 04-15-2018, 05:46 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 28
Likes (Received): 39
In my opinion, the older Murray/Noma machines are quite solidly built. And Murray parts are usually quite available. Some of the parts are fairly universal.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #7 of 9 Old 08-20-2019, 06:03 PM
I found that the impeller and gearbox parts and the auger shaft bushings seem to be common to many Murray/Noma/Craftsman models. However taking my Noma 5/24 apart to replace the impeller assembly (the shaft was bent when I got it) was not an easy task. Now I am facing the task of getting the impeller shaft through the auger housing bearing when I put it back together. I bought a new bearing (6203-2RS a commonly available inexpensive part) and am waiting for some 00 grease and a couple of other parts I ordered on amazon.com.
murray1575 is offline
post #8 of 9 Old 12-02-2019, 08:50 AM
Thanks (Given): 63
Thanks (Received): 59
Likes (Given): 115
Likes (Received): 79
Did you see the recent post on Murray gear boxes using Lubriplate GR-132 low temp grease? You will probably be just fine with the 00 but I am just pointing this out.
How are you going to straighten that shaft? Big ass hammer?
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #9 of 9 Old 12-16-2019, 10:22 AM
Do you have a parts list/diagram for your 23/24 noma?
SnowRO is offline
