Cannot find this model ANYWHERE - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-13-2019, 09:30 PM Thread Starter
Bstal98's Avatar
I have a Murray made Noma snowblower, model G2450000. This unit has 2 cables that serve to engage the auger. One cable goes from the handle to a metal pin at the bottom rear right side of the unit....this cable is fine. The cable I need starts at the metal pin, goes in the underside of the machine, crosses under the transmission, comes up and out of the machine and across the top to connect to the pulley and engage the auger. I cannot find a proper manual or parts list for this machine anywhere, an I've ordered cables, but they're all too short. I think the one I need will be 30+ inches. It is branded Noma, but has Murray as the manufacturer on the plate with model and serial numbers. Can anyone help me? I'd prefer to buy a cable and do it rather than pay hundreds for someone else to.
Bstal98 is offline
post #2 of 11 Old 01-13-2019, 09:45 PM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 403
341024 auger cable may work
post #3 of 11 Old 01-13-2019, 10:24 PM
Thanks (Given): 17
Thanks (Received): 34
Likes (Given): 57
Likes (Received): 83
Murray Cables
I had this file from a Snowblower I sold at some point.
I have a pic of the unit, but file will not up load. The traction cable is listed as part number 1580 32.19" long
An updated part number is probably 1580MA , as a Briggs number.
This is the website I used to get the parts breakdown:
https://partsandservice.com/
GLuck, Jay
JayzAuto1 is offline
Likes db130 liked this post
post #4 of 11 Old 01-14-2019, 06:22 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
132619 is offline
post #5 of 11 Old 01-18-2019, 01:22 PM
G2450-000
Originally Posted by Bstal98 View Post
I have a Murray made Noma snowblower, model G2450000. This unit has 2 cables that serve to engage the auger. . . The cable I need starts at the metal pin, goes in the underside of the machine, crosses under the transmission, comes up and out of the machine and across the top to connect to the pulley and engage the auger.
I cannot find a proper manual or parts list for this machine anywhere. . .
Go to the following link and request they post the pages you need:
https://partsandservice.com/html/Mur...g2450-000.html
They have a total of 12 pages for your model that are available, but not yet online. I believe that the third one in the list is most likely to be the correct one: If so, it is described as "340578-853" which is, typically, the first or nearly the first part number listed on the page. The title to the page you want is probably "Frame Components Assembly" and the cable you need is probably listed as "Cable, Auger" and is probably Item 108.
For my G2914-010 (your machine's big brother!), the part number is 3410240 (mentioned in a previous reply in this thread) but, since my machine is larger (29", 10 HP), I don't know whether it would be the part you need. "My" part is readily available from many sources as Briggs & Stratton part #3410240MA for around or a bit under $20. (I know this because I am waiting for one to get here, hopefully on Monday, so we can fix my machine!)
I hope the above is useful for your machine.
JERRY, N3AA
1996 Murray "Brute" G2914010, 10 hp, 29", walk-behind snowthrower w/Tecumseh SnowKing HMSK-100
1982 Craftsman GTV 11 (917.253715)
Sears 46-inch dozer blade (917.254020) + Lift Mechanism (917.254050)
Sears 44-inch mower deck (917.253644)
Sears 9.1 cu. ft. Dump Cart (610.26351)
Sears 36" Trailer Lawnsweeper (426.260921)
jhorwitz is offline
post #6 of 11 Old 01-18-2019, 01:48 PM
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 59
Likes (Given): 56
Likes (Received): 90
Maybe besides the model number you could describe this Unit a bit.
How many HP? 5,6,7,8,9,10,11,12,13???????
How big is it??? 22, 24, 26, 28 30,32,33,34 inch bucket/auger housing???
This model comes up with close numbers:
https://www.searspartsdirect.com/mod...Term=D2450-000
SimplicitySolid22 is offline
post #7 of 11 Old 01-18-2019, 01:52 PM
Thanks (Given): 51
Likes (Given): 56
post #8 of 11 Old 01-18-2019, 02:01 PM
Thanks (Given): 51
Likes (Given): 56
post #9 of 11 Old 01-18-2019, 06:53 PM
It's a 24-inch wide two stage and 5 HP. It's the "baby" of four "kids in the family" of which mine is the largest.
The basic model number starts with the width (in inches) and the next digit represents the horsepower. Not sure about the 4th digit--it might specify manual start or electric start, but I am not sure about that. Three additional digits (which may be with a hyphen in front or not--I've seen it both ways) probably represent minor model options, changes, or updates. I think the "G" prefix may indicate a significant change in the models (like model years on a car, perhaps) as I have seen listings for other prefixes ("F" I think and, possibly others).
The four models in the group below all share the same Operator's Manual but they don't all share the same Parts Manual (my Parts manual only covers my exact model). My manuals are both dated June 1996 and I bought the machine in (I think) October of that year.
G2450, 24 inch, 5 HP;
G2454, 24 inch, 5 HP;
G2784, 27 inch, 8 HP; and
G2914, 29 inch, 10 HP
JERRY, N3AA
jhorwitz is offline
post #10 of 11 Old 07-27-2019, 04:35 PM
I just bought the same machine from a neighbor at a garage sale. While the engine runs it needs some carburetor work which I already have parts for. It also has a flat tire which will not hold air. I located a used replacement wheel which I should receive in a few days. I looked through this thread and found that the D2450-010 mentioned is probably the same machine except for the year of manufacture. I suspect that most of the parts will be the same. I look forward to getting this machine working well to replace the 40 year old Toro 421 which I am currently using.
murray1575 is offline
