2004 Murray "BRUTE" 10HP 29" - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-29-2019, 05:41 PM Thread Starter
toofastforyou's Avatar
Likes (Received): 10
I recently bought a 2004 "BRUTE" snowblower model 629106X83B in very nice shape but when the winter's over, I plan to take it apart and have all the yellow parts powdercoated. For some reason, only the yellow needs to be redone as the black components (wheels, engine, chute, etc…) all look ok, but my main question is this: Does someone know where to buy original REPLACEMENT DECALS for it? I don't want to restore it and leave it without any decals. Right now, I found a place to have them reproduced but it looks like it will be a little expensive (but I'll still have them made if I don't find original ones).
Any help would greatly be appreciated!
Thanks,
Claude.
ID:	152591   Click image for larger version
ID:	152593   Click image for larger version
ID:	152595   Click image for larger version
ID:	152597   Click image for larger version
ID:	152601   Click image for larger version
ID:	152603   Click image for larger version
toofastforyou is offline
Likes eyebolt liked this post
post #2 of 7 Old 01-29-2019, 05:55 PM
Thanks (Given): 89
Thanks (Received): 175
Likes (Given): 68
Likes (Received): 406
There are many local sign shops and T shirt shops that do this work if you have a good picture. They will take that picture, import it, print it on adhesive.
post #3 of 7 Old 01-29-2019, 08:27 PM Thread Starter
Thanks for your reply…I already contacted someone who does that but I was trying to find some original decals first but if I don't, I won't have no other choice but to have them made.
Thanks again,
Claude.
post #4 of 7 Old 01-30-2019, 08:32 PM Thread Starter
When you buy something "used" there are always some little "issues" to fix to make it right, and today I found a few "things" which needed to be fixed. First while clearing my driveway, one of the belts let go so I replaced both 'cause I don't know when they were replaced in the past and also I noticed that one of the wheels was secured by a nut and bolt instead of the pin with ring spring (pictured below) so tomorrow, I'll get the correct one to replace the bolt.
…and back to my original post, does someone know where to find the original decals?
Claude.
post #5 of 7 Old 01-30-2019, 08:58 PM
Thanks (Given): 41
Thanks (Received): 52
Likes (Given): 139
Likes (Received): 117
I know this isn't your model, but some may apply, and if you dig around the various Brute models you may find more: https://www.jackssmallengines.com/ja...-group-2989394
Paul
1995 Toro 724, 1988 Toro 521
paulm12 is online now
post #6 of 7 Old 04-25-2019, 12:58 PM Thread Starter
I finally ordered a complete set of decals from Nate at www.clickitandatickit.com for my snowblower which I bought used in February and which I'm going to start restoring pretty soon. I am still waiting for them to get here. Total cost was $125. for all the decals. As soon as I receive them, I plan to disassemble the whole snowblower (and take numerous pictures while doing so) and send everything to be powdercoated in the original color and them when it gets back, I'll reassemble it and put on the decals for the final touch. Should look great! I might post some pictures of "before vs. after" here on the site...
Claude.
2014 HUSQVARNA ST327T
2004 MURRAY BRUTE 10HP 29"
1975 LAWN BOY 8HP 26"
post #7 of 7 Old 04-25-2019, 02:38 PM
Thanks (Given): 41
Likes (Given): 139
yes, please post up some pics during assembly and after. Looks like a fun project.
Paul
