30 year old Dynamark 825 Model number? Need wheels!! - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-01-2019, 10:47 PM Thread Starter
Post 30 year old Dynamark 825 Model number? Need wheels!!
Folks,
Last year, I'd gotten a 30 year old, Dynamark 825 blower. The engine is a Tecumseh HM80-155310M - Serial 7293C made on 10/21/1987.
I can see the serial number of the blower is 701864 with "78" near it a bit smaller. But the model number has faded.
I called Murray, then Briggs (who's taken over these, as far as replacement parts are concerned).
They told me it was "Similar to Craftsman Trac Drive 8HP 25" model #536.884900". That can't be right as far as the drive goes, as mine is not track drive. It has `2x5.00-6 Sno Hog tires, on 3/4" ID rims, with the pin-hole and Schrader valve on the outside of the rim. The following picture is from a #536.886520, and it shows the tires I have, but Sears Direct doesn't have the part number for item#675 (the wheel assemblies). https://c.searspartsdirect.com/lis_p...9119-00007.png
I need new wheel assemblies. I had some hack-tire-change-guy try to get new tires on the rims and now the rims are garbage and won't hold air. So, I need new tires with air in them, that will fit. Mostly, anything with that size tire and axle size (3/4") will work. There are generally two types...one that is shorter than the other by about 4" in the back. So that it sits flat on the floor, when the valve is "up".
Although the unit originally came (to me 30 years after manufacture) with tires with the the longer 3/4" bushing on it, these were frozen on the axle, so I made some Delrin bushings that mimic what Murray or Cub Cadet does on their axles, and got 2 Cub Cadet wheels from Craigslist. Then I grease up the axle with anti-seize. (some of these wheels's I've seen have zerk fittings to make greasing easier...this would be a nice-to-have, but optional).
Feel free to post here a link to buy these, or feel free to DM me.
Regards,
Ambidexter
P.S. Attached is a photo for a Carlisle X-Trac which is the right size and shows the pin hole and valve. I've seen Sno Hogs that work too.
Ambidexter is offline
post #2 of 4 Old 02-02-2019, 09:11 AM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 406
I have the same machine. Wheels appear to be interchangeable between all makes and models. Look on Craig's list. Cost should be between $15-$40 for two.
post #3 of 4 Old 02-02-2019, 09:52 AM
oneacer's Avatar
Thanks (Received): 15
Likes (Received): 49
You might be able to put a tube on those rims, unless he really trashed them.
I use one of those small tire changers for snall wheels from harbor freight, with small tire irons, works great. Makle sure you lube the tire.
They also make split rims, I have them on 2 of my machines, with tubes of course, works great.
I use Sno-Hog, but X-Trac work well also.
Example:
https://www.bmikarts.com/6-Split-Rim...rn_p_1570.html
oneacer is online now
post #4 of 4 Old 02-03-2019, 11:04 AM
The_Geologist's Avatar
Likes (Given): 40
Likes (Received): 16
Do you have any small engine repair shops nearby? I have one here that lets you pick and pull from their "salvage yard".
I bought an entire snowblower similar to yours for $20. I needed the engine, wheels, and a few other things off of it - the problem was apparently something with the drive/transmission that the PO didn't want to spend money on.
Just a thought, though I do realize this probably isn't the best time of year to be searching through a salvage yard...
Adam
Flathead Valley, MT
1980 Ariens ST824
1990s Toro CCR1000
The_Geologist is offline
