impeller shaft bearing install - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 10-16-2019, 04:56 PM Thread Starter
Murray Ultra 2-stage 8HP 27" G2784030, purchased 1997. The impeller shaft bearing is shot. I had a devil of a time removing it, probably because of some corrosion on the shaft? I put the nut back on the end of the shaft and a wood block on that, then gave it whacks until I worked it off. I've watched videos of impeller/auger assembly removal and they just "pull it out" from the front. Question is, how is that possible? It can't be a press-fit bearing then right? I'm assuming the shaft/bearing should be a very close fit but doesn't require a pressing tool. I believe the bearing retainer grips the outer race, and the shaft spacer exerts some pressure on the inner race?
My plan at the moment is to take some fine sandpaper to the shaft until the bearing can traverse it by hand, then do the reassemble. Sound right?
bradholcomb is offline
post #2 of 5 Old 10-16-2019, 05:23 PM
Jackmels's Avatar
Thanks (Given): 108
Thanks (Received): 164
Likes (Given): 347
Likes (Received): 645
Bearing Should Slide on the Shaft. Clean the shaft with Sandpaper or a wire wheel, and use some oil.
Jackmels is offline
Likes Zavie liked this post
post #3 of 5 Old 10-16-2019, 05:29 PM
Sid
Thanks (Given): 10
Thanks (Received): 23
Likes (Given): 28
Likes (Received): 33
If you got it off by hitting a piece of wood makes me think that it wasn't much of a press fit, it probably was the crud/rust that sort of held it on. Clean up the shaft, and the outer bearing holder and the new bearing should fit fine. I try to use a socket or a piece of pipe to match the inner race to "tap" it on the shaft.The outer race should slide into the recess. Always check a new ball bearing for smoothness, no sandy or lumpy feeling as you rotate it by hand.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is online now
post #4 of 5 Old 10-16-2019, 05:30 PM
Zavie's Avatar
Thanks (Received): 90
Likes (Given): 398
Likes (Received): 184
Yes. Watch Donyboy73's video if you want to see a tough to remove auger. Donyboy does kick it's a$$
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #5 of 5 Old 10-16-2019, 06:03 PM Thread Starter
Thank you all! Gotta keep this beast running! Just like my 38 year old Kenmore washer and dryer! Thank goodness for Google, YouTube, FixItNow.com, etc.
