Murray 8hp 27" Wheel lock & release problem - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 12-29-2015, 08:28 PM Thread Starter
Model 627804x6a S/N S001587761683
I'm new to your site but have read most every topic I thought applied to me and couldn't find the answer I need.
I picked this up last year, no idea what year it is but it's in excellent shape and it worked great. First snow of the year last night and had an issue with the wheels locking up under load. Going along blowing and all of a sudden wheel lock, give it a good shove and start moving again for a couple feet and then same issue. Sometimes I have to rock it to and fro to free them up. With no load it drives perfectly. When I tip it on the hood the wheels move freely, friction plate and rubber drive wheel in very good shape along with a new belt. What's causing the lock up?
Mur278 is offline
post #2 of 20 Old 12-30-2015, 01:35 PM
Thanks (Received): 112
Likes (Received): 292
Does this machine have power steering clutches on each handle?
Work fascinates me.
skutflut is offline
post #3 of 20 Old 12-30-2015, 04:31 PM Thread Starter
No, it does not. Just drive and impeller.
Mur278 is offline
post #4 of 20 Old 12-30-2015, 05:18 PM
Jackmels's Avatar
Thanks (Given): 95
Thanks (Received): 148
Likes (Given): 280
Likes (Received): 590
Sounds to me like a broken or missing return spring for the Drive Plate Assembly.
Jackmels is offline
post #5 of 20 Old 12-30-2015, 05:43 PM Thread Starter
I'm not sure what or where that is but the drive plate returns to neutral without issue. Of course it is returning while not running or under load.
Mur278 is offline
post #6 of 20 Old 12-30-2015, 05:48 PM
I assume you have checked the friction wheel, and friction disk for oil or grease and both are squeeky clean?? You might need to tighten up on the cable adjustment for the traction clutch to get a tighter fit of wheel to disk
Work fascinates me.
skutflut is offline
post #7 of 20 Old 12-30-2015, 05:51 PM
Thanks (Received): 87
Likes (Received): 275
s it really locking or is it slipping? My guess is slipping and the belt is not able to handle the extra load. You might check that the belt is no to long and the tension is good.
post #8 of 20 Old 12-30-2015, 05:53 PM Thread Starter
The friction wheel & disk are very clean and make strong contact. I'm not having an issue getting it to engage but with the wheels being locked up and not moving while disk is engaged. I'm very handy but definitely feeling snowblower stupid........
Mur278 is offline
post #9 of 20 Old 12-30-2015, 05:53 PM Thread Starter
Not slipping, wheels locking. Belt is new and tightens nicely.
Mur278 is offline
post #10 of 20 Old 12-30-2015, 05:58 PM
Likes (Received): 20
Possibly some worn bushings are allowing a jackshaft to **** just enough to bind things up?
sidegrinder is online now
