Auger belt too loose; pops every time disengaged - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-04-2016, 02:22 PM Thread Starter
I have one of the 27" E2784-000 models that is a very common system, same as many MTD, Craftsman and other models.
Just this year, the auger belt is really loose and jumps off the larger auger pulley when I disengage the hand control
Everything looks aligned
The bearings do not appear to be shot (no play in the auger pulley if I try to push it.
I have a new correct 585416 v belt on it.
I can actually roll the belt over the large pulley when the tensioner is adjusted.
The tensioner arm doesn't LOOK like it is traveling more than it did; there are no wear marks to judge this however.
ideas? Maybe the belt is too long? it is actually a Murray part and has the part number on the belt
There is no obvious source of play in the system
I'm not missing any belt guides (looking at part diagrams to confirm)
I'm stumped! Thanks or any help!
Geezer is offline
post #2 of 15 Old 02-04-2016, 02:27 PM
Thanks (Received): 87
Likes (Received): 275
typically there should be a belt guide that prevents it from coming up above the pulley - maybe it's missing or loose? (Looks like a bent wire rod)
post #3 of 15 Old 02-04-2016, 02:33 PM Thread Starter
there are two small guides on the small motor mounted pulley. no problems there.
There was never any guides on the large auger pulley.
I should not be able to put the belt back over the large auger pulley without loosening the tensioner...it's just too loose
Geezer is offline
post #4 of 15 Old 02-04-2016, 02:47 PM
Thanks (Given): 509
Thanks (Received): 679
Likes (Given): 3830
Likes (Received): 1472
You mention you have a "new correct belt on it". Did this problem start after putting on the new belt ??
Is that belt number physically on the belt itself ??
post #5 of 15 Old 02-04-2016, 03:19 PM Thread Starter
yes, the part number is on the belt and sleeve and are the right part number
When I prepped the blower for the blizzard two weeks ago, The belt that was on it popped off the auger pulley and got fubar when it popped off the pulley (so it was too big). I usually have two auger belts in with my shear bolts and misc parts so I may have just put the belt that got messed up on at the end of last season after the last usage. I do not remember. The belt was in very good shape.
There is nothing on the diagram or on the unit that looks likes it limits the travel of the auger tensioner so I do not think there is wear and the tensioner is traveling "too far"
I probably got the two belts from the same place and they were both Murray OEM.
The belt that got messed up seems to be the right length
If you look on the next page of the parts diagram, the tensioner arm doesn't have any adjustment or wearing parts
The auger housing is not cracked or rusted
there is no adjustment on the motor/gear box chassis to auger housing
---still stumped and until now I thought of myself as reasonably mechanically inclined. I may have to turn in my "man-card"
Geezer is offline
post #6 of 15 Old 02-04-2016, 03:49 PM
Thanks (Received): 112
Likes (Received): 292
No, don't turn in any cards yet. You will find a solution, it might just take a bit of time for all the others to read this thread and have an "ah ha" moment.
Work fascinates me.
skutflut is offline
post #7 of 15 Old 02-04-2016, 05:46 PM
Sid
Thanks (Given): 10
Thanks (Received): 23
Likes (Given): 28
Likes (Received): 32
Try a 1/2" shorter belt. If you don't get it dirty, you can take back.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #8 of 15 Old 02-04-2016, 10:01 PM
Likes (Received): 10
ive had issues with blower belts popping off before.. and for me it was the idler pulley bearring being shot... would slooowly tighten the nut holding itself and bam! cause problems.. so do check the idler pulley.. does it spin freely and smoothly?? does it wobble?? is there an adjustment on it you may have had to loosen up and didnt quite tighen down enough this time?? the tensionner spring on the cable ( if your handle does have that) is it tighten properly(does it tighten at least midway to engaging the augers)?
if everything checks out. then for some strange reason.. you have the wrong belt lenght on there..
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
post #9 of 15 Old 02-06-2016, 02:16 PM
Looking at KFrog's diagram, the number looks like 585415 for part #63 identified as Belt, v-4 aug. drive.
Pythons37 is offline
post #10 of 15 Old 02-06-2016, 04:39 PM Thread Starter
so...
I got a 1/2 38" V Belt from Grainger (the OEM belt is nominally 38 3/8")
I put that on and the while the belt didn't pop, the auger pulley wobbled like a drunken sailor.
I ordered these part numbers
49562 and two 313873
Other suggestions?
Geezer is offline
