Honda 1332 augers and auger housing - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 27 Old 02-20-2019, 09:55 AM Thread Starter
SnowSquatch's Avatar
Originally Posted by SnowSquatch View Post
Originally Posted by jrom View Post
Not jumping in on how/why, but prices from boats.net are a lot better that what you posted. Augers for $105.74 each and the bucket for $439.51.
Like Red and vmax have said, I'd weld up the bucket, add armorskids then replace at least the most worn auger myself (pretty easy) then get a backup blower because I think you're gonna need one, probably sooner than later.
https://www.boats.net/catalog/honda/...-1000001/auger
https://www.boats.net/catalog/honda/.../auger-housing
Thanks! Now that’s some relief on the pocket book! I will be looking today. Huge help man. Class act!
And Jrom, what is the easiest way to change the auger. Just the quick version. What am I looking for to get it out of the housing?
SnowSquatch is offline
post #12 of 27 Old 02-20-2019, 10:33 AM
jrom's Avatar
Thanks (Given): 347
Thanks (Received): 107
Likes (Given): 1066
Likes (Received): 188
I've taken my '91 HS828 augers apart and it's super easy. Haven't done auger maintenance yet on my 1332, but basically you take the auger housing bracket off, disconnect the auger transmission from the blower (impeller) shaft, remove the side bearing bolts, then slide the auger assembly and auger transmission out (as one unit), then you disassemble each auger from the auger trans shaft (which does not run the full length of the auger assembly).
If you plan on keeping your 1332 and you want to save $ and down-time, I'd invest in a shop manual.
Honda HS828TAS (1991) Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is online now
post #13 of 27 Old 02-20-2019, 10:49 AM
orangputeh's Avatar
Thanks (Given): 747
Thanks (Received): 223
Likes (Given): 1502
Likes (Received): 1488
tough love is sometimes hard to swallow.
i have worked on hundreds of Honda's and can not believe the abuse and neglect i see from owners who do not know how to maintain their machines. ( and don't want to learn ) I guess they don't mind wasting money.
I sold a beautiful 928 to a property management owner who placed the machine in the back of his truck and started throwing bicycles on top of it. I yelled at him and offered his money back for the machine because could not stand the abuse. Turned down the contract to service/repair his other 11 Honda's.
It's a real shame and waste.
"It Feels Like Beer O'Clock "
orangputeh is online now
Likes WVguy liked this post
post #14 of 27 Old 02-20-2019, 11:00 AM
jrom's Avatar
Thanks (Given): 347
Likes (Given): 1066
Since I haven't done it yet, I'm just looking at my shop manual and guessing you may only have to take one shear bolt off the blower (impeller) shaft (Honda calls it the joint pipe), then two auger shaft bolts (one on each side) on the outside of the auger housing, then take off two (on each side) bearing holder bolts (4 total) that are on the inside of the bucket.
You should then be able to slide the entire auger and trans assembly out.
If you have the HSS1332AATD / HSS1332AACTD, the auger bracket has a limit switch you have to disconnect and take out of the way to slide the auger assembly out.
After that it looks like you can slide the auger bearings, bearing holders and spacers off the auger drive shaft, then remove the two auger shear bolts, then slide the augers off the auger shaft.
jrom is online now
post #15 of 27 Old 02-20-2019, 11:07 AM
jrom's Avatar
Thanks (Given): 347
Likes (Given): 1066
I know you've learned a lot from this site and you've also helped a lot of us out and that is really cool.
Before I joined here I came close to being one of the "dead from the neck up" guys by not keeping an eye out on my rear skids (on my 828) and I wore the scraper bar low enough to start chewing up the bottom edge of the bucket.
I've since learned the error of my ways ...I think
jrom is online now
post #16 of 27 Old 02-20-2019, 11:14 AM
orangputeh's Avatar
Thanks (Given): 747
Likes (Given): 1502
my passion sometimes gets the better of me.
being borderline bi-polar does not help things.
post #17 of 27 Old 02-20-2019, 11:23 AM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
Originally Posted by RedOctobyr View Post
Definitely agree on having a backup blower of some kind. Especially while establishing your customer base and reputation.
You don't want a broken belt, failed chute switch, etc, to leave you unable to clear your customers.
Those prices from boats.net look a lot better. You could keep the old augers for an emergency, or maybe weld on a new strip of steel along their edges, etc.
I suspect that *any* side skids would be a big help. Though lots of people do like the ArmorSkids, maybe they'd be perfect. I think they sell a thicker Pro version of their skids.
Good luck!
Sound advice indeed. I blow snow commercially with HS 928 hondas. Oh my, it would be a real nightmare without at least 2 machines. Hondas are pretty reliable. But even well maintained they let you down, usually at the worst time. Thats when you go back to the shop drop off the broken down one and pickup your spare and back on the trail. Do the repair when the weather gives you a break. I dont do any where near 50 drives and I wont be without backup machines and a good supply of the common wear parts. Being reliable is everything!! Clients dont want to hear broke down, they want their drive cleared and on time. What I have found over the years is this. You need multiple machines. Trying to get by with one is just not going to work. For a short time maybe, but it will catch up with you. Before I got into Hondas I had a hard time to get thru a major storm with a few backups. Sometimes down to the last one and fingers crossed. Like the saying goes, its the little things that will get ya down. A small simple part and your out of service.
Properly adjusted side skids are the ticket to save your bucket. I put side skids and raised the rears so the side skids do the work. Works for me. More than 10 years on my blowers and no wear on the bucket and only minimal on the augers. Keep them adjusted, skids wear surprisingly fast. Pro Armour skids are great no question, the base is about 1/2 inch thick and will go longer without adjustment due to the larger wear surface.
Prime is offline
Likes jrom liked this post
post #18 of 27 Old 02-20-2019, 11:25 AM
jrom's Avatar
Thanks (Given): 347
Likes (Given): 1066
I hear ya. Bummer on the borderline BP, I know quite a few people who have it, thankfully it can usually be controlled, but I know (as the song says) It don't come easy.
jrom is online now
post #19 of 27 Old 02-20-2019, 11:37 AM
Thanks (Given): 145
Thanks (Received): 321
Likes (Given): 429
Likes (Received): 766
I'm sure they must have their reasons for using them, but anecdotally, it seems like maybe Hondas suffer from worn buckets and augers more than other brands. And I assume this is at least somewhat due to the rear mounted skids. Offering less control over the front of the bucket, and maybe being tougher to monitor for wear?
An advantage I can think of is the bucket has a narrower profile (no skids at the sides), more like a knife, so it can better punch into icy/firm snow.
But after that, the rear skids seem more like a liability to me, helping cause needless wear.
Is there a big benefit to them that I'm missing? I haven't gotten to own a Honda, so I have to go by what I read.
post #20 of 27 Old 02-20-2019, 12:15 PM
jrom's Avatar
Thanks (Given): 347
Likes (Given): 1066
I think you're right and I think it's a bad design.
You may be right on the narrow profile angle too. I put the first 20 hours on my 1332 without side skids.
After adding them, it became harder to use the blower up to tight spaces like trees, rocks and even clearing a previous path that may have ice chunks frozen to the ground. The blower will sometimes hit then jump up if the frozen chunk is big enough or super glued down. It was a smoother operation before side skids, but the bennies far outweigh the negatives.
An advantage I can think of is the bucket has a narrower profile (no skids at the sides), more like as knife, so it can better punch into icy/firm snow.
jrom is online now
Similar Threads
Honda Used 1332 Snowblower Q&A Forum043287 Honda Snowblowers 0 01-12-2019 10:19 PM
Difference HS and HSS Augers and Auger Tranny orangputeh Honda Snowblowers 10 10-27-2018 08:57 AM
Honda stuck augers removal YSHSfan Honda Snowblowers 6 03-23-2018 05:42 PM
Honda HS622 augers jammed -Help Lutes Honda Snowblowers 5 06-30-2017 12:09 AM
ST724 924048 Auger housing question pma1123 Ariens Snowblowers 2 09-26-2014 05:47 PM
