Brand new honda hssa928td snow blower - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 12-04-2019, 04:22 PM Thread Starter
Unhappy Brand new honda hssa928td snow blower
Hello Pros,
I just got a brand new Honda Snowblower and used it last night for the first time. We got 5-6" of snow and it had an issue lagging/stalling under load. I can't figure it out! Everything was correct, that I knew of but when I got to like 4-5" of slushy snow at the edge of my driveway it would bog and almost shut off?? Please help. I spoke to Honda and the dealer and they said it shouldn't do that, not with this one! Thank you, Angelo
napoli1as is offline
post #2 of 17 Old 12-04-2019, 04:25 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 57
Likes (Received): 182
throttle not set right or fuel mix set wrong.
else get dealer to figure it out imo
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #3 of 17 Old 12-04-2019, 05:08 PM
JnC
JnC's Avatar
Thanks (Given): 62
Likes (Given): 26
Likes (Received): 212
Just upjet it to #92 and increase the RPM, otherwise the dealer isnt/cant do anything to help the sluggishness.
JnC is online now
post #4 of 17 Old 12-04-2019, 05:23 PM
Did you go real slow at the thick slushy part? This stuff usually will not throw well, at least you didn't break any shear pins. Did it throw the normal density snow fairly far? Remember to post your solution when you arrive at one. This may helps future readers out.
Plowking is offline
Likes Dag Johnsen liked this post
post #5 of 17 Old 12-04-2019, 05:47 PM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 560
Likes (Received): 254
Upjet for 5-6"?? OMG
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #6 of 17 Old 12-04-2019, 06:22 PM
JnC
JnC's Avatar
Thanks (Given): 62
Likes (Given): 26
If the conditions are right then these machines will clog even with 2~3" of snow. Its usually the heavy/wet stuff that gives them issues especially the GX270 powered HSS928s.
JnC is online now
Likes Rooskie liked this post
post #7 of 17 Old 01-02-2020, 09:27 AM Thread Starter
Thank you and Happy New Year all for the responses and very sorry for the late check in. I never got the update emails!! My Honda does great with regular fluffy snow, yes. I did break a shear bolt on the slushy stuff. I will keep on eye on what I am doing to make sure the adjustments are where they need to be. It does loo like Honda did revise the chute design a bit more to open up the opening on the new model I have but still clogs due to the flat platform edge at the bottom of the chute. It is too wide which allows the snow to build up . If they decrease that ledge it should work better.
post #8 of 17 Old 01-02-2020, 09:28 AM Thread Starter
Should of I gone with the Ariens Rapid Trac???
post #9 of 17 Old 01-02-2020, 09:54 AM
penna stogey's Avatar
Thanks (Received): 21
Likes (Given): 120
Welcome to the SBF and congrats on the Brand spanking New Honda!!
2019 Ariens Compact 24...
penna stogey is online now
post #10 of 17 Old 01-02-2020, 10:07 AM
kimber's Avatar
Likes (Given): 51
Likes (Received): 26
This is one of the reasons I went with the rapidtrak over the Honda but there are things you can do to remedy clogging, re-jet your carb, increase rpm's, install an impellar kit, lots of guys have done this to their machines with great results!
Honda makes the best small engine in the buisiness (IMO) and once you do the mods, you'll have a great machine that should outlast you!
Best of luck, keep us posted.
kimber is online now
