Predator engine surging on my john deere snow blower - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 12-30-2016, 12:48 AM Thread Starter
Smile Predator engine surging on my john deere snow blower
Hi I repowered my John Deere 1032 snow blower with a 420 CC item 69736 Predator engine from H.F. I did all the rework including new motor base plate, bigger pulleys and belt guard. The problem I am having is the engine surges at mid range and full throttle. When the engine is warmed up and running under load or no load it surges at full throttle and mid range throttle. The engine is 4 years old. I did a few things to the engine. First, I purchased 2 gallons of new gas and mixed in 4 oz of sea foam. Second, I drained the Predator fuel tank of old gas and poured in the new fuel mixture. Third, I disassembled the carburetor, fuel bowl, removed float and needle seat, removed main jet. Fourth, I proceeded to spray carb with carburetor cleaner in the holes and openings that I could see ( fuel bowl was really clean so was carb). Fifth, reassembled cleaned carburetor. Sixth, started engine with the sea foam mixture, however still had the surging problem. Seventh, I then proceeded to pour sea foam in the intake while the engine was running. Eighth I opened up the choke about an 1/8 to a 1/4 and surging almost totally went away. Finally the engine still surges but not as bad as before all this work was done. called H.F. They where no help at all. Oh by the way This is a non adjustable carburetor. There are two brass plugs in the carburetor castings. could be adjustments screws behind brass plugs? Well I am not sure where to go from here? Thanks P.s. modifying blower to have lights and two electric power chutes and electric start. I live in CT. Thanks Aypsears
Aypsears is offline
post #2 of 21 Old 12-30-2016, 01:15 AM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
The engine is jetted stock to run at summer temperatures and I would suggest moving up 1 jet size or enlarging the jet slightly with a drill bit or a torch tip cleaner until the surging goes away. I have 2 Predator 212cc engines on snowblowers and I enlarged both of the jets on them so that they run well with no choke on at tempertures colder than 32 F.
GustoGuy is offline
post #3 of 21 Old 12-30-2016, 01:55 AM Thread Starter
Hi Thanks for the tip. Is there a bigger main orifice and main nozzle for sale? if not what size drill to use thanks aypsears
Aypsears is offline
post #4 of 21 Old 12-30-2016, 09:12 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Re Jetting
GMorning AypSears, I found the site Affordable Go Karts.com that has jet kits, assortments and how-to video's. There are sooooo many variations, that it may be misleading to suggest a size to punch out the jet you have. The best way is working live on the machine, trial and error. The site is the real deal, informative and has many upgrades available. Worth checking out. GLuck, J
JayzAuto1 is offline
post #5 of 21 Old 12-30-2016, 09:48 AM
Likes (Received): 280
Yeah - if it runs better when you choke it some - she's running to lean. You can buy very small drill bits at harbor freight...... just work your way up in small changes.
post #6 of 21 Old 12-30-2016, 10:43 AM
Likes (Received): 42
If you don't want to tackle rejetting, it's perfectly acceptable to apply a little choke on the airflow side. If your surging stops, you have adequately corrected the air mixture problem. What you don't want to do is run a lean mix engine at full throttle. If, on the other hand, added choke results in a drop in rpm's or a loss of owner, you will have to try the jet route. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #7 of 21 Old 12-30-2016, 10:43 AM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Larger jets are available on eBay for $6 with shipping, search for "[.xxx] clone jet" with xxx being the size. For example, ".032 clone jet"
The factory jets on the Predator 212CCs are believed to be .028. I've run .032 jets with the air cleaner removed with good results (I've also used the adjustable jet).
db130 is offline
post #8 of 21 Old 12-30-2016, 06:26 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
I've even had them hunt, with the jet drilled out to .032. I had to go to .034, to get the hunting to stop.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #9 of 21 Old 12-30-2016, 06:36 PM
Likes (Received): 303
Do you have a pic of the carb? I know they used several suppliers and some guys cut into the casting to get at the idle circuit jet. Could just buy a Honda aftermarket carb or OEM and see if it changes. "Some" OEM Honda carbs are very reasonable.
post #10 of 21 Old 12-30-2016, 07:55 PM
Thanks (Received): 148
Likes (Given): 215
Likes (Received): 305
The replacement carb in the photos HEREshow an adjustment screw. Probably just idle mixture based on the location.
dbert is offline
