Slight problem with repowering - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 03-16-2017, 10:59 AM Thread Starter
So my old aircap industries (1988) 5/22 snow blower with the tecumseh 5hp motor **** the bed half way through this past season. I repowered it with a predator 6.5hp and blowing through 12" of snow was quite easy and as usual, started first pull out of the box.
Now a problem I encountered (which is presumably my fault) is that all Predator motors spin counter clock wise.. my old tecumseh spun clock wise. So now I have a fairly quick 1st gear (which is reverse on the gear lever) and have 3 settings for reverse I assume there's nothing I can do correct?
It's not a big problem for me since when I was pushing it is just moved and wasn't much of a hassle
Tomekkplk is offline
post #2 of 10 Old 03-16-2017, 11:36 AM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
The Tec and the Predator both spin the same direction. You need to adjust the Friction wheel's position.
Jackmels is offline
post #3 of 10 Old 03-16-2017, 12:10 PM Thread Starter
I wish it were that easy, I don't have a friction plate on mine. It has a hydrostatic drive, hence why I thought the motor spun in the opposite direction
post #4 of 10 Old 03-16-2017, 12:16 PM
Jackmels's Avatar
I've Never Seen a Tecumseh that Ran in the "Opposite" Direction. Maybe Someone else has.
Jackmels is offline
post #5 of 10 Old 03-16-2017, 05:00 PM
Thanks (Received): 112
Likes (Received): 298
Did your old engine have two drive pulleys on different shafts, one for wheels and the other for the auger, also knows as a twin shaft?
Work fascinates me.
skutflut is offline
post #6 of 10 Old 03-16-2017, 05:03 PM
Likes (Received): 483
I'm suspecting a dual shaft previous engine as well.....
YSHSfan is online now
post #7 of 10 Old 03-16-2017, 05:32 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
I recently passed on a nice real deal Troybilt with a geared transmission like yours. The old Tecumseh was a dual shaft where the transmission drive pulley is driven clockwise.
Not sure if there is a feasible way to Spin the transmission so it's driven in the right direction.
drmerdp is offline
post #8 of 10 Old 03-16-2017, 06:19 PM
Thanks (Received): 97
Likes (Received): 259
What happens with your impeller's rotation ?
RIT333 is online now
post #9 of 10 Old 03-16-2017, 06:47 PM
Impeller should be fine.
I think it was a dual shaft engine originally on which the cam pto (that turns on the opposite direction) is what moved the drive on the unit, therefore operating backwards with the predator since it has a single shaft.
He should also be experiencing about twice the speed.....
post #10 of 10 Old 03-16-2017, 09:26 PM Thread Starter
Yeah it had a dual shaft, now that I think about it. A bit annoyed with how it worked out but like I said before, it moves forward with little effort in neutral
