Toro Power Clear single stage 212cc... correct re-power? - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 11-04-2017, 04:01 PM Thread Starter
Local buddy has a 721E with a burned out crankshaft bearing (ran out of oil). I'd love to swap in the Predator 212cc but am unsure what shaft adapters I'll need.
I know there are a TON of resources for two stage blower engine upgrades. I'd like to complete a power swap for a single stage Toro.
The Toro engine is a Loncin LC170FDS-2 but I see Loncin makes that engine with a ton of different crankshaft lengths and diameters. The Toro engine part number is 121-4225, described as LC170FDS-2. I found the basic Loncin engine but don't know what shaft is right.
I also don't know the HF engine's equivalent Loncin number. So i can't even say the Predator is the same LC170FDS-2 as the Toro, irregardless of the shaft question.
I see the Predator 212cc has the following specs:
Shaft diameter 3/4 in
Shaft length 2.43 in. / 61.7 mm
Keyway 3/16 in
1. Does anyone know the shaft specs for the Toro LC170FDS-2 engine?
2. Does anyone know the Loncin engine number for the Predator 212cc?
Much appreciated -- I'll keep the group updated every time I learn something. Hopefully this can become the thread for single stage Toro re-powers.
bryanska is offline
post #2 of 3 Old 11-25-2017, 09:50 PM
the predator engine is a loncin 210fa in disguise
post #3 of 3 Old 03-02-2019, 03:52 PM
i know this has been a while, but did you ever find this engine? i have a Toro 721 that probably will cost me more to put together so i will part it out.
Patrick Miller is offline
