Repowering Toro 3521 w/ 179cc Engine - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 12-05-2017, 07:21 AM Thread Starter
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
I have my original 179cc (5.5 HP) engine from my Troy-Bilt 2410 sitting, waiting for a machine to run.
I came across this Toro 3521, needing a new engine. Figuring that the original 3.5 hp engine is a bit light for a 21" machine, I planned to put the 179cc engine in its place
the 3521 is basically the same machine as it's big brother, the 521. Here is the 3521 alongside my re-powered 521.
Repowering Toro 3521 w/ 179cc Engine-img_0618.jpg
The 179cc is a decent fit
Repowering Toro 3521 w/ 179cc Engine-img_0620.jpg
Both my 521 and this 'new' 3521 need an impeller bearing. So, I did some 'minor' disassembly . . .
Repowering Toro 3521 w/ 179cc Engine-img_0623.jpg
I figure, while the machine is apart, I'll give it a quick coat of paint to spiff it up a bit.
Then I could either sell it this winter as a capable small/agile machine or keep it as another spare
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #2 of 29 Old 12-05-2017, 07:25 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Lookin' good Ted! You're going to need a "5"521 label now.
What are you going to do with the Tec side-popper?
('87 Toro 38150 826)
Likes tpenfield liked this post
post #3 of 29 Old 12-05-2017, 07:56 AM Thread Starter
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
You mean the old 3.5 Tecumseh? not sure . . . I'll see if I can get it to run, then maybe sell on CL. I'll want to do a compression test and leak-down test on it to see how 'good' it is.
I suppose I could re-brand the 3521 as a 5521
Regards, Ted
post #4 of 29 Old 12-05-2017, 09:16 AM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 172
lookin good. I'm thinking a more powerful "5521" could be very useful.
paulm12 is online now
Thanks tpenfield thanked for this post
post #5 of 29 Old 12-05-2017, 06:18 PM
Likes (Given): 12
Likes (Received): 11
Looks good! My new to me 3521 got a similar freshening up, but with the ubiquitous Predator 212.
If you find a dead later 521, the taller chute is almost a bolt on for the 3521, with only minor changes necessary at the base.
1971 Ariens 922002 (sold)
198x Toro 3521 with Predator 212 and tall chute
sciphi is offline
post #6 of 29 Old 12-05-2017, 06:34 PM Thread Starter
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
Yes, my 521 has the Predator. I did notice the smaller chute, but I'll see how it works first with the standard chute. I have seen the taller chutes from 521's on eBay $20-$50 range.
Regards, Ted
post #7 of 29 Old 12-05-2017, 07:18 PM
the smaller chute lows just as far lengthwise but struggles when it comes to throwing over snowbanks
post #8 of 29 Old 12-06-2017, 04:57 AM
Likes (Given): 1882
Likes (Received): 663
the short chute does not throw as far as the tall chute, my 2450 was throwing snow farther than my 521 when it had the short chute on it. if you are keeping the 3521 put the tall chute on it but if you are selling it leave it as is, it won't make a difference of what someone will pay for it and it won't be a selling point
post #9 of 29 Old 12-06-2017, 07:48 AM Thread Starter
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
If I were going to keep this machine, I'd get the taller chute. As it stands, I'll probably sell the machine and use the cash to buy an 824 in need of some TLC.
Regards, Ted
post #10 of 29 Old 12-10-2017, 05:27 AM Thread Starter
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
I have the impeller bearing (bushing) ready to be installed, but . . .
Since I had the machine apart, I took care of the rust and put a fresh coat of paint on everything.
Repowering Toro 3521 w/ 179cc Engine-img_0634.jpg
I masked areas off to save the decals
Repowering Toro 3521 w/ 179cc Engine-img_0635.jpg
I used my $9 HVLP sprayer that I got recently from Harbor Freight and mixed my own Toro Red, since the local stores did not seem to have the Apple Red.
Next steps are to put it all back together and fit the 'new' engine on it. I will have to make some pulley modifications as the Troy-Bilt engine has a 7/8" diameter shaft, and the Toro pully is a 3/4" diameter. So, my plan is to use the pulley assembly that came with the Troy-Bilt, but the positioning is a bit off. So, I'll have to do some modification of the Troy-Bilt pulley set.
Regards, Ted
