414cc Stormforce on 1032 Ariens - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-10-2017, 11:46 AM Thread Starter
Thanks (Received): 212
Likes (Received): 767
well friends....I bit the bullet and ordered the Stormforce 414cc engine from smallenginesuppliers.com and it arrived yesterday. $149 plus $70 for shipping for an LCT winter engine with electric start...how can you beat it! Thanks to Shaw 351 for supplying the link and idea in the first place! I really like the thought of the big six blade impeller on the Ariens coupled with that 414cc engine..... Now I've got to strip the Ariens for new paint....weld a crack in the bucket, replace bearings etc. as needed, and swap a new set of handles to replace the broken ones on the 1032. Then figure out the engine swap! Shaw....would you change pulley diameter, or keep it stock? Also tips on mounting the engine...I couldn't find the thread you had on this.....
cranman is offline
post #2 of 11 Old 12-10-2017, 12:34 PM
Thanks (Received): 98
Likes (Received): 260
WOW - they have tremendous prices. Any idea where they are located ? Wonder if you could buy direct to avoid the shipping charge - although it isn't that expensive - these are heavyitems.
RIT333 is online now
post #3 of 11 Old 12-10-2017, 12:40 PM Thread Starter
Much heavier then a 212 Preditor for sure...Shaw....I finally found the post for your 1032 build with the 414...good stuff.
cranman is offline
post #4 of 11 Old 12-10-2017, 12:56 PM
you will probably need a wait. i have a predator 420cc on mine and it works great with factory pulleys. i have the belt dimensions if you decide to go with factory pulleys
post #5 of 11 Old 12-10-2017, 03:55 PM Thread Starter
I'll go with factory if it performs well ....what are the belts you used?
cranman is offline
post #6 of 11 Old 12-10-2017, 06:18 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Cran, how bout some pics?
Jackmels is offline
post #7 of 11 Old 12-10-2017, 06:58 PM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
SES has the best prices around, I too found them to by the lowest and fastest , I needed a new kohler twin for my personal cc tractor when the SV 730 twin gave up. they helped me find a drop in k745 for 650 plus 90 for fedex ground to my door.
other places were hundreds higher
5 stars all around for them
10953 is offline
Thanks cranman thanked for this post
post #8 of 11 Old 12-10-2017, 08:48 PM
me and my buddy did the same swap and we towed his blower to the auto parts store and test fit is the parking lot. this pic should save you about 2hrs of bs
post #9 of 11 Old 12-10-2017, 08:50 PM
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 110
Just checked that site out. It asks for a quote request for prices. Makes it tough to shop and compare on the site. Or is it just me. Is there a trick to the site. Like creating an account?
74 Ariens 832
8? FMC Bolens 824
02 White 4x4 Snow Boss
90 Lawn Boy ST320
88 Honda 300FW w/plow
guilateen02 is offline
post #10 of 11 Old 12-10-2017, 08:56 PM
I just looked at the website works for me.
Just go half way down click on snowblower motors you will see all of them
MrDman is online now
