Thoughts on re-powering Toro PowerMax 724 - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-25-2018, 11:52 AM Thread Starter
Question Thoughts on re-powering Toro PowerMax 724
Hi fellows, new here, but mechanically inclined.
I intend to re-power my Toro PowerMax 724 Briggs & Stratton 900 Snow Series for a B&S 1450 Series.
Basically my engine is a 12D105-0172F8 model and the one I'm looking at is model number 20M307-0001-F1
Same Shaft diameter and basically the same length.
As any one ever did this swap?
Thanks for your input.
Makriluc is offline
post #2 of 17 Old 01-25-2018, 12:37 PM
Likes (Received): 1384
You are going to have to get different belts maybe. other than that it should be a piece of pie. ALOHA from the Paradise City.
post #3 of 17 Old 01-25-2018, 01:04 PM Thread Starter
Thanks Powershift.
That's what I tought. Should not be that big of a deal to swap
Makriluc is offline
post #4 of 17 Old 01-28-2018, 02:24 PM Thread Starter
Ok.
Just wanted to keep you posted on my engine swap.
the engine I bought is a B&S 1450 Series moldel 20M307-0001-F1.
Correction for my snowblower, it is a Toro PowerMax 726.
The new engine is a bolt-on on the base of the snowblower. The base plate is already pre-drilled for the mounting of the 1450 series. No modification what so ever. Belts align perfectly. Now I just have to wait for some snow.
My only question is; that I read on other posts that I shouldn't go WOT during breaking period. Is this true?
Thanks for your input and thanks to POWERSHIFT93 for his comments
Makriluc is offline
post #5 of 17 Old 01-28-2018, 03:35 PM
Originally Posted by Makriluc View Post
Ok.
Run the engine full bore open for 5 hrs using dino oil. then after the 5 hrs is gone with the Schwinn. then you can use whatever brand weight of oil that suits your fancy.
post #6 of 17 Old 01-28-2018, 03:51 PM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
did a 928 38801 powermax from a 265 cc loncin to a 1128 ,38680 spec brigs 342 cc https://www.smallenginesuppliers.com...gines1855.html, from a earlier year not one issue direct bolt on, pulley was a bolt on ,i used the 1128 belts to play safe as the briggs crank center line is 1 inch higher
if careful it's not hard to swap with a bigger motor turning a bear into a cougar.
10953 is offline
post #7 of 17 Old 02-01-2018, 03:14 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
I swapped to that exact engine on a Troy-Bilt 2410 (got rid of the original 179cc engine). Probably not much difference in making the swap, as you will just need to find the matching bolt holes on the chassis of the Toro, which it sounds like you did. I'm not in love with the Briggs 305cc 1450 series, but it is OK. It has the 60 watt charging system, so you can connect to lights or add them as needed.
Here is a link to my thread: https://www.snowblowerforum.com/forum...b-s-305cc.html
Since the shaft dimensions are about the same (as you indicated), I assume that you were able to re-use the pulley(s) from the original engine, which simplifies matter greatly.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #8 of 17 Old 02-01-2018, 04:02 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
to SBF Makriluc
You sure won't feel any lack of power in that setup !!
post #9 of 17 Old 02-01-2018, 04:55 PM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
I'm just finishing up a similar re-power on a Toro 724, it's not a powermax (I don't really know the difference) IT's an older model, I had to re-route the chute rotation, which I don't think is a problem for you. .
It's basically a straight forward swap.
jsup is offline
post #10 of 17 Old 02-02-2018, 05:38 AM
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
PowerMax has the joystick chute control and the recirculating impeller housing. Most of the current-day engines on a re-power tend to interfere with the old-style chute control shafts. Something to consider beyond just the mounting dimensions.
@Makriluc - got some pictures of the re-powered machine?
Regards, Ted
