mtd old snowblower 5/22 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-25-2018, 01:28 PM Thread Starter
mtd model # 315e611d352 tecumseh 6.5 hp double shaft not working. i swap with predator 212cc. my gear a REVERSE. can i fix it ?
Can i fix it
twin shaft tecumseh to harbor freight predator 6.5hp on mtd 5/22 snowblower. but the gear are reverse.
Why and i can fix it?
Paul Pieretti is offline
post #2 of 13 Old 01-25-2018, 01:29 PM
Likes (Given): 21
Likes (Received): 30
Yup.
Jatoxico is offline
post #3 of 13 Old 01-25-2018, 01:49 PM
Likes (Given): 21
The cam spins reverse and drives the trans right? What type of trans? I have same situation and have a full gear box not a friction disk but since I'm not having any trouble I have not investigated. Add a gear, somehow run the belt figure 8? IDK. Maybe a search or someone can chime in. Undoubtedly you're not the first.
Jatoxico is offline
post #4 of 13 Old 01-25-2018, 01:54 PM
Likes (Given): 21
What's wrong with the current 6.5 BTW?
Jatoxico is offline
post #5 of 13 Old 01-25-2018, 01:55 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Take the case apart and find out why it's not spinning, there are gears in there.
If your snowblower uses a dual shaft you can't use the Predator because it's a single shaft unless you swap the undercarriage from left side to right.
JLawrence08648 is offline
post #6 of 13 Old 01-25-2018, 04:31 PM
Originally Posted by JLawrence08648 View Post
Take the case apart and find out why it's not spinning, there are gears in there.I
I wonder if he could just set it up so his reverse gears(s) are now his forward one and forwards would be reverse. I general only use 1st and 2nd forward. Mine has 2 reverses but some might only have 1 and that would be limiting if it became the only forward.
38racing is offline
post #7 of 13 Old 01-25-2018, 04:40 PM
Likes (Received): 483
Being an MTD you may get lucky a just be able to flip the shifter lever to reverse drive directions. It still will be faster but the direction will be right.
There is at least one youtube video about how to do it....
You can also search here on the forum for re powering dual shaft engines snowblowers to a Predator
post #8 of 13 Old 01-25-2018, 04:40 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
its been done plenty of times, some machines are easier than others and results may vary . ground speed can be an issue.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 13 Old 01-25-2018, 10:35 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Yes you can. Here is a link from 5 years ago on what I did to repower my old MTD with a Predator 212cc.
https://www.snowblowerforum.com/forum...light=gustoguy
https://www.snowblowerforum.com/forum...w-machine.html
GustoGuy is online now
post #10 of 13 Old 01-28-2018, 08:12 AM
Thanks (Given): 80
Thanks (Received): 35
Likes (Given): 96
Likes (Received): 97
I have an 8/26 with a dual-shaft engine and what I've found is that there are a lot of used engines out there, and pretty cheap too. When mine gets tired or grenades, that is the route I'm going.
2015 Ariens Deluxe 28
Previous Machines:
1995 Yard-White-Bilt 8/26 Frankenblower
1980 Toro 826
1981 Toro 3521
Clutch Cargo is offline
