Briggs Intek 206cc install on Ariens 924032 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 02-24-2018, 10:47 PM Thread Starter
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I recently had to buy a pair of snowblowers (the seller had 4 non-runers to get rid of and was running out of storage space. He would not sell me just the one I really wanted). I managed to fit both snowblowers in my wagon.
Believe it or not, the one I really wanted was the single stage Ariens 722EC shown on the right (7hp from an 139cc engine), but I guess there's nothing wrong with picking up a cheap 7hp 924 series snowblower.
The old Tecumseh had compression but I just could not get it to start up even after cleaning the carb. I decided to swap it out with a Briggs Intek. The donor was a Craftsman pressure washer with a dead pump that I picked up for peanuts. It is 206cc in size, 6.5 hp and burns clean (OHV design).
This is a nearly drop-in replacement. It uses the same engine mount holes as the Tecumseh (once you knock out the original studs), same belts, same pulley (I needed to buy a 3/4" to 1" crankshaft sleeve). The original chute crank even clears the valve cover if you use a longer eye bolt and bend the eye bolt slightly.
The snowblower chassis needed 2 axle bushings and a friction wheel which was easy enough to take care of. If we ever get snow again in Massachusetts this season, I'd love to try it out.
db130 is offline
post #2 of 13 Old 02-24-2018, 11:44 PM
Likes (Received): 303
222
post #3 of 13 Old 03-06-2018, 11:16 AM Thread Starter
Thanks (Given): 16
Likes (Given): 241
I fished out a tall chute from my parts bin, it came out of a 924050 that I bought for parts back in 2015.
Also added the missing Ariens logo with a used one on eBay, "just because."
I plan on replacing the tires with used Snow Hog tires (just acquired a Craftsman snowblower with a 9hp engine and 6" Snow Hogs) down the line.
db130 is offline
post #4 of 13 Old 12-02-2018, 12:50 PM Thread Starter
Thanks (Given): 16
Likes (Given): 241
Well, here's a long overdue update... I could not stand the mismatching handlebars any longer, and I found a parts snowblower that had a much nicer Ariens nameplate and white handlebars in good condition last night and picked it up this morning (the parts snowblower also yielded a teardrop bucket+cast iron gearbox which will go to a different snowblower project).
Here's the parts machine I picked up - the nameplate and handlebars are in decent shape:
This is not a great picture of the new handlebars installed on the snowblower, but you can see that the mismatching handlebars are now gone. I might put the orange short chute back on when it's time to sell, or maybe i'd leave that choice to the next owner.
db130 is offline
post #5 of 13 Old 12-04-2018, 08:00 AM
Thanks (Given): 9
Likes (Given): 43
Likes (Received): 35
looking good.
KOBO is offline
post #6 of 13 Old 12-04-2018, 09:48 AM
Thanks (Given): 172
Thanks (Received): 70
Likes (Given): 1217
How do you like the single stage Ariens 722EC?
gibbs296 is offline
post #7 of 13 Old 12-04-2018, 10:05 AM
Thanks (Given): 21
Thanks (Received): 17
Likes (Given): 96
Likes (Received): 82
WOW!!! I could not help think of myself nursing my old Bolens 32'' with a 12 HP Tecumseh engine purchased new in 1986. Finally chuck the towel in an purchased a new Ariens 28 Pro.
You have done an OUTSTANDING job restoring your old machine https://www.snowblowerforum.com/foru...ies/bowing.gif
foggysail is online now
post #8 of 13 Old 12-04-2018, 12:15 PM Thread Starter
Thanks (Given): 16
Likes (Given): 241
Thanks for asking!
I buttoned it up using parts from the 522 from this thread -> I pulled the electric starter from the 522 and put it on the 722EC and got one good working machine out of it.
I don't think I got to test it out much after I fixed it up due to lack of snow, and I also picked up a nice Toro CCR3650 to compare against.
A "shootout" will follow as soon as I have snow on the ground.
db130 is offline
Thanks gibbs296 thanked for this post
post #9 of 13 Old 12-07-2018, 02:57 PM
Thanks (Given): 172
Likes (Given): 1217
Originally Posted by db130 View Post
Thanks for asking!
I'm looking forward to your shootout, both nice machines!!
gibbs296 is offline
post #10 of 13 Old 12-08-2018, 01:57 PM
Nice job. We did a nut and bolt level restoration of a 1970 Ariens about 15 years ago. Still in use.
Had to drill new mounting holes but the shaft height and diameter is the same.
CarbineMan is offline
Likes Seaweed liked this post
