420cc Predator Re-Power Projects - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 03-08-2018, 07:09 PM Thread Starter
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
My next summer project will be a re-power of a bigger blower using this engine
Can you post some pics of yours and briefly explain what was involved (ie was it a simple bolt-on or an engineering feat)
(or drop in the link to an existing thread)
1989 John Deere 1032
tdipaul is online now
post #2 of 3 Old 03-12-2018, 07:14 AM
Guest
Likes (Given): 48
should be a pretty much easy swap,might be some drilling of the mount base, or the shaft to long as the specs are Shaft 1″ x 3.48″,Keyway 1/4″ (6.35 mm),End Tapped 3/8″ - 24.
no matter 13 hp on a blower makes one powerful machine, best of luck man.
old ope mechanic is offline
post #3 of 3 Old 03-12-2018, 07:26 AM
Guest
Likes (Given): 48
https://manuals.harborfreight.com/ma...9999/69736.pdf
12 volt starter 300cca 36 amp battery needed might be the only issue with where and how to mount it.
