Replace an HMSK80 with an HMSK100? - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-18-2018, 09:21 AM Thread Starter
Thanks (Given): 80
Thanks (Received): 35
Likes (Given): 96
Likes (Received): 97
These past couple of noreasters with heavy wet snow have got me thinking that I either need to get a new(er) machine or perhaps upgrade the engine. Yes, I know all about repowering with a Predator, and I know there are work-arounds for when you have a dual shaft HMSK engine. However, I'm thinking that if I could find a decent HMSK100 PTO long block, it would be a pretty easy upgrade. I have also seen new HMSK100 short blocks on Ebay for pretty short money. However, they are all single shaft, but I thought I saw a thread showing how the PTO shaft can be retrofitted using the same cover. Is this true?
Any thoughts/insight will be appreciated.
2015 Ariens Deluxe 28
Previous Machines:
1995 Yard-White-Bilt 8/26 Frankenblower
1980 Toro 826
1981 Toro 3521
Clutch Cargo is offline
post #2 of 6 Old 03-18-2018, 09:25 AM
Likes (Received): 345
Big thing would be if both covers were the same dimensions with same bolt pattern. If they matched then likely would work, if not then the won't.
HCBPH is online now
Thanks Clutch Cargo thanked for this post
post #3 of 6 Old 03-18-2018, 09:32 AM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
8-10 side covers are the same, and you can swap the 8hp cam and cover to the 10hp engine. However, MTD and Similar use a different Style Crank.
Jackmels is offline
post #4 of 6 Old 03-18-2018, 11:02 AM Thread Starter
Thanks (Given): 80
Likes (Given): 96
Therefore, if I understand you correctly, the shaft length/diameter is different?
Previous Machines:
1980 Toro 826
1981 Toro 3521
post #5 of 6 Old 03-18-2018, 04:33 PM
Likes (Given): 469
Here's a Photo of MTD Crank
Jackmels is offline
Likes Clutch Cargo liked this post
post #6 of 6 Old 03-19-2018, 09:14 PM Thread Starter
Thanks (Given): 80
Likes (Given): 96
Thanks!
Previous Machines:
1980 Toro 826
1981 Toro 3521
