Looking for new engine for Ariens 30" Platinum Snow Blower - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 04-15-2018, 02:36 PM Thread Starter
I am looking for a new engine for my Ariens 30" Platinum Snow Blower. I was blowing some very wet icy slush and it suddenly made a loud noise like something cracked and now when I pull the recoil to start it, there is little to no resistance. Checked the crankcase and there appears to be gasoline in the crankcase where the oil should be and it is black in color. It was not that way when in the Fall and was only used twice all winter. The rest of the snow blower is like new so I think it would be cost effective to replace the engine but I cannot seem to find anyone who sell a complete replacement engine. Thanks.
Blizzardbob is offline
Likes Iceracer liked this post
post #2 of 14 Old 04-15-2018, 04:05 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
throw a big predator on it, you then might have 12v electric start.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 14 Old 04-15-2018, 04:22 PM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
Welcome to the forum! Sorry to hear about the failure, that sucks. It sounds like gas drained through the carburetor, most likely, and got into the cylinder, the leaked past into the crankcase, contaminating the oil. Oil with gas in it doesn't lubricate as well; from the symptoms, it seems like maybe the connecting rod broke.
Can you post any info from the engine? That might help people who don't know exactly what's on your machine.
Also, posting where you're located might help. It's possible that someone here might have an engine for sale, if they're near you.
post #4 of 14 Old 04-15-2018, 07:54 PM Thread Starter
The engine on my snow blower is an Ariens 342 cc 16.50 ft-lbs gross torque Polar Force Briggs and Stratton engine. Ok, here's the kicker, I live 20 miles from the Ariens Headquarters and Manufacturing Plant in Brillion, WI. If I can't find a replacement engine, is there any way to repair mine. I have had this snow blower for 5 to 6 years and used it maybe 15 times at the most. Everything else associated with the snow blower is in excellent condition. I know either solution is not going to be inexpensive but still less than spending $1700-1800 for a new one.
Thanks Dauntae thanked for this post
post #5 of 14 Old 04-15-2018, 08:03 PM
Thanks (Given): 590
Likes (Given): 4374
Likes (Received): 1743
to SBF Blizzardbob
Harbor Freight sells 6.5, 8 and 13 horse https://www.harborfreight.com/engine...s-engines.html
You can also find engines at Home Depot, Menards, Farm Supply Stores like Fleet Farm, Tractor Supply ... https://www.homedepot.com/s/briggs%2...izontal?NCNI-5
Someone just got a good deal on a dusty 8hp Briggs a Hardware store had on clearance. Pays to look around and don't forget to search your local area on Craigslist for an engine or a broken machine with a good engine. Get the whole thing and pull the engine and then just post the rest of it for free parts and whatever is left post a free scrap metal ad and it's gone.
There are also some interesting articles on fixing the block with JB Weld if you might be interested in that.
post #6 of 14 Old 04-15-2018, 08:05 PM
Thanks (Given): 590
Likes (Given): 4374
to Re-Powering
post #7 of 14 Old 04-15-2018, 08:21 PM
Thanks (Given): 174
Likes (Given): 480
How handy are you, and how much of a project are you open to?
If nothing cracked the engine block, or put a hole in it, then maybe you got lucky, and the connecting rod broke without destroying the block. If you had the interest, time, and patience, you might be able to open up & rebuild your engine internals, for less than the price of a new engine.
Or you could go with a different, replacement engine. Like the Harbor Freight Predator engines that were mentioned, which are fairly inexpensive, and have a good reputation. But that will take a little more research than just getting an exact replacement for your engine.
The (probably) most-expensive, but most-straightforward option is to get the exact model number of your engine, and see if you can buy a replacement. Calling Ariens would be worthwhile on that front, it's possible they could help guide you to a replacement.
On my Tecumsehs, there is an overall model number, like HMSK80, then there is a more specific number that captures the detail of how the engine is configured. If you find a more-specific number like that for yours, maybe you can find a drop-in replacement.
Googling "342cc Briggs Polar Force" came up with this, as a point of reference. Note that it shows two different configurations of that engine, with two different crankshaft sizes. If you want to find something that can just be swapped easily, you'll need to check the specific engine model # of yours. You might be able to use something with a smaller-diameter crankshaft, but you might need to add a sleeve to use your existing pulleys on the smaller-diameter crankshaft, for instance.
342cc/16.5 GT Snow Briggs & Stratton Horizontal Engines
post #8 of 14 Old 04-16-2018, 05:24 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
to SBF
Keep in mind that Ariens does not make engines, they buy them. . . obviously from Briggs on this machine. How old is the machine? Warranty?
OPEengines.com is another place where folks, including myself, have bought engines. SmallengineSuppliers.com is also where folks have bought engines. Harbor Freight is another quick/easy source.
See if you can get the dimensions of the output shaft so you can get a replacement with the best fit.
I would look/Google a Briggs & Stratton 16.50 GT Intek engine for the best match to your existing engine, and search for the best deals. Also, if you get the numbers off of the engine, (not the blower) that may help. Current Briggs 16.5 engines have a model number that starts with "21M314"
powerequipmentdirect.com has one listed
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #9 of 14 Old 04-16-2018, 07:55 AM
tpenfield's Avatar
Thanks (Given): 48
Likes (Given): 131
https://www.kohler-engine-parts.opee...-342cc-p-52261
Seems like one of the better deals, but not exactly inexpensive.
Regards, Ted
post #10 of 14 Old 04-16-2018, 10:13 AM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Why don't you dig into that one and see what actually broke? A lot of times, complete replacement in not only not needed, but not cost effective . . . . If the block is OK, might be a fairly simple repair.
tadawson is offline
