ST1032 Needs a New Engine - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-09-2018, 03:34 PM Thread Starter
CMS
Hi All,
The engine on our ST1032 (Model 924084 SN 001421) just died and is a Tecumseh HMSK100 159119T. My question is not regarding repairing this engine, it has been nothing but problems its whole life, and now the crank is done, it is about a replacement engine. I have searched but I still don't see a direct replacement engine for this particular model?
The question is what is the closest "drop-in" replacement engine I can purchase? I don't want to be doing too much customization but don't mind drilling new mount holes. I just don't want to be fabricating a new belt guard or searching for the correct pulley. Buying a new belt and drilling some mount holes is one thing but beyond that I will likely just junk the machine.
I am not partial to any engine brand but do want an engine that is reliable especially in cold weather.. Any model numbers of engines you'd suggest? Any links to ST1032 repower blogs etc. with instructions would also be greatly appreciated..
Thanks!
CMS is offline
post #2 of 10 Old 12-09-2018, 03:49 PM
Thanks (Given): 587
Thanks (Received): 768
Likes (Given): 4352
Likes (Received): 1734
to SBF CMS
to Re-Powering
I haven't re-powered one so I've never done the research. Someone likely has the info you're looking for and can help you out.
post #3 of 10 Old 12-09-2018, 04:21 PM
Thanks (Received): 212
Likes (Received): 767
You can repower with a used Tecumseh....a ton of them around...check with JackMels....Most of the Chinese clones will bolt on with little effort. If you get one with a 1" shaft, should be a piece of cake. Check the section of this forum about repowering.
cranman is offline
post #4 of 10 Old 12-09-2018, 04:48 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 663
https://www.harborfreight.com/engine...epa-60349.html
a bit pricey, but should sit right on ( foot print/bolt spacing and shaft height are given)......chute rotation rod could be the only issue.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #5 of 10 Old 12-09-2018, 05:20 PM
aldfam4's Avatar
Thanks (Given): 250
Thanks (Received): 46
Likes (Given): 733
Likes (Received): 135
Is the Tec engine single shaft or dual shaft?
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #6 of 10 Old 12-09-2018, 06:04 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
It would be Helpful if People Looking for Parts Would List Their Location.
Jackmels is offline
post #7 of 10 Old 12-09-2018, 07:12 PM Thread Starter
CMS
Single shaft Tecumseh. Assuming that is what "Tec" means???
CMS is offline
post #8 of 10 Old 12-09-2018, 07:14 PM Thread Starter
CMS
With the internet these days...... Regardless, the machine that needs an engine is in Maine..
CMS is offline
post #9 of 10 Old 12-09-2018, 07:19 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Tec means Tecumseh, what is your location and budget, LCT has a 414cc with a 1”shaft and LCT is the maker of the Ariens AX series of engines on the new machines, I’ve seen a few on eBay for $260 or so. But if your in Mass Jackmels I am sure has some used Tecumseh engines for sale.
Dauntae is offline
Likes Jackmels liked this post
post #10 of 10 Old 12-09-2018, 07:25 PM
aldfam4's Avatar
Thanks (Given): 250
Likes (Given): 733
Harbor Freight sell the single shift (13 HP - 420 CCs) for about $325. - $350. Nice looking engine. I believe it is a 1" shaft also.
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
