Need New Engine - Snowblower Forum : Snow Blower Forums
post #1 of 78 Old 12-17-2018, 02:48 PM Thread Starter
Thanks (Given): 21
Likes (Given): 7
Likes (Received): 16
Need New Engine
I have an older ST1028LE I purchased at Home Depot years ago. The engine was noisy from day one and blew the first 2 ft of the first storm the following year. Home Depot said I needed to go through Tecumseh and they said I had to go through Home Depot saying, the floor models have no oil and everyone and their uncle pulls on the recoil. I went out and bought a replacement snowblower and had the engine sitting in the garage ever since.
Well, I decided to see if I could rebuild it and found the case had cracked around the starter mount. I'm not sure if it's worth rebuilding and wondering if someone could lead me toward a replacement. Thanks in advance.
niteshft is offline
Likes Dkeith45 liked this post
post #2 of 78 Old 12-17-2018, 02:52 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 423
Likes (Received): 664
Have a look at harbor frieght or princess auto. Other than that , look for a rusted out machine with a suitable engine on the cheap.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Thanks niteshft thanked for this post
post #3 of 78 Old 12-17-2018, 03:00 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Might be helpful to add a location to your profile so we have an idea of what might be possible for giving you leads or where shipping would be reasonable.
Likes Jackmels, Dkeith45 liked this post
post #4 of 78 Old 12-17-2018, 03:01 PM
Thanks (Received): 212
Likes (Received): 767
It sounds like the rod let go....order a rod on E-bay, new I last paid $28....tap the crack in the block so it is flush with the outside of the engine and use three coats of JBWeld very thin. Install new rod and go....make sure you open the case before you order the rod...may be more damage to the motor then just the rod.
cranman is offline
post #5 of 78 Old 12-17-2018, 03:17 PM Thread Starter
Thanks (Given): 21
Likes (Given): 7
@cranman I have a mig welder...I suppose I could weld it. It's a long crack that goes across the starter mounting area and down a bit on each side. I'm not sure I would trust JB for that.
niteshft is offline
post #6 of 78 Old 12-17-2018, 06:09 PM
I've done a dozen with JB weld...I have aluminum welding capability , but JB weld works great....just has to keep the oil in.....I'll bet a 3 inch strip of Flexseal would do it.....
cranman is offline
post #7 of 78 Old 12-17-2018, 06:17 PM
Thanks (Given): 175
Likes (Given): 464
Likes (Received): 1044
Do a google search for snowblower engine 10HP.
post #8 of 78 Old 12-17-2018, 06:53 PM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
This may help. http://nh.craigslist.org/for/d/engin...747192088.html
ID:	150139   Click image for larger version
russ01915 is offline
Likes niteshft liked this post
post #9 of 78 Old 12-17-2018, 07:19 PM
I like the Chondras, but being cheap, I'd fix the Tec if fixable.....
cranman is offline
post #10 of 78 Old 12-17-2018, 08:14 PM
Thanks (Given): 590
Likes (Given): 4371
Would like to see photos of the crack but it sounds like it might be salvageable. I haven't tried the JB trick but I've come across a lot of guys who have. If the crank is good then a new rod and some JB and you could be good to go. I've read about ways to polish the crank to remove any aluminum from the crank and leave the journal clean for a new rod.
