Toro S-200 runs fine then stalls Help! - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-11-2019, 04:52 PM Thread Starter
Greetings from Ohio!
I have a Toro S-200 with a Tecumseh engine. It starts up fine and runs well for about 10 - 15 minutes. After that it just stalls. It starts right back up and within a minute or so it stalls again. I have tried running it with the gas cap loosened and it doesn't help. My guess is something is heating up and making it stall. I'm pretty handy and can replace the coil, points, condenser etc. I just need a little advice to be pointed in the right direction. I appreciate everyone's time and advice!
knewbomb is offline
post #2 of 3 Old 02-11-2019, 05:42 PM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
Welcome to the forum! I'd start by checking whether you still have spark after it stalls. Also, try spraying a bit of (mixed) gas into the carb after it stalls, then see if it will briefly re-start from that fuel. Between the two, you'll get a better understanding of whether you're dealing with a spark problem, or a fuel problem. Does it have a fuel filter? If it's fuel-related, you'll want to check that the filter is flowing freely.
post #3 of 3 Old 02-11-2019, 05:51 PM
Thanks (Received): 44
Likes (Received): 114
I think you may be correct that something is heating up and making it stall. IMO I think you may have water in the gas that has frozen into ice and as the unit warms up it starts acting up. That is the first thing I would check. I would pull the carb bowl and check the tank for signs of water or ice in either. Water can plug up the carb jet holes and block the bottom of the main jet intake.
Just a guess.
Most electronics (coil, condenser, ign. module etc.)do not take 15 minutes to heat and die. and they usually will not refire until it has cooled off completely.
Lottstodo is offline
Similar Threads
70's Ariens or 80's Toro Trandy General Snowblower Discussion 4 12-20-2017 07:06 PM
Nearly impossible to start, but runs fine. Coil? Glove Snowblower Repairs and Maintenance Forum 16 02-11-2015 10:06 PM
New guy, my SS Honda vs Toro vs Simplicity comparison Fo-Time General Snowblower Discussion 28 01-10-2015 02:05 AM
Honda HS720C vs Toro 721QZR BMR General Snowblower Discussion 16 10-29-2014 10:28 PM
Ariens 24 vs. Toro PowerMax 724 ? Spokaneman General Snowblower Discussion 17 11-23-2013 02:29 PM
