cheap 208 cc engine from E-bay critique - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-15-2019, 03:34 PM Thread Starter
Thanks (Received): 212
Likes (Received): 767
Hey Gang.....I just opened the MTD 208 cc engine crate that arrived today from E-bay....going to share some observations. First the pluses. The engine was only $79 including shipping...it has an alternator....glove ready recoil....convenient oil dip stick and filler tube on top of engine....primer bulb....heat box...extended oil drain tube. Now the negatives.....no fuel shut off...no throttle....the ignition shutoff is with one of those funky plastic keys that ground out the engine when you remove it...it has a dial on the top of the aircleaner that restricts the airflow coming into the air box....perhaps to shut of the engine????...and lastly, I was hoping that the 25 mm shaft was a close fit to a 1 inch pulley....no it isn't...a few thousandths slop. The last 3/4 in of the shaft is necked down to 7/8 in, but that doesn't leave any room for aligning. I went on E-bay just now and ordered a 2.36 diameter pulley with the 25 mm bore for $10...but it has no keyway, so I'll have to machine one in. I also have a friend that manufactures cranberry equipment that can cast me and machine any aluminum pulley to what ever diameter or bore size I choose. All in all comparing the pluses and minuses, I'll stick to Harbor Freight for the Chondras. I'll swap this one onto a 73 or 74 10000 series Ariens so I only have one pulley to worry about.
cranman is offline
post #2 of 10 Old 02-15-2019, 04:30 PM
Thanks (Received): 44
Likes (Received): 114
Just a note if you get the chance check out " small engine warehouse"
I check them before I order from HF or anybody else. They sell brand new scratch and dent,and brand new take off engines.
I just told a guy to order the LCT 291 snow series from them for 239.00 the recoil has a poulan decal but it is the exact same motor on the Ariens 28 dlx that they blew up with no oil.
Lottstodo is offline
post #3 of 10 Old 02-15-2019, 05:39 PM Thread Starter
I bought a 414 cc engine from them 2 years ago...$169 plus 70 shipping.......I wasn't looking for an engine...just wanted to check out the 208cc one.....
cranman is offline
post #4 of 10 Old 02-15-2019, 05:45 PM
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
Keep us posted on how it runs!!!! Thanks for the update.
SimplicitySolid22 is offline
post #5 of 10 Old 02-15-2019, 08:59 PM
Thanks (Given): 21
Thanks (Received): 17
Likes (Given): 96
Likes (Received): 81
That deal was a lot better than what I find at Harbor Freight
foggysail is online now
post #6 of 10 Old 02-15-2019, 10:18 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Hey cranman.....
Those were a great deal back then, I bought 4 of them and used on 32" machines. They worked out well and I haven't had one call for any issues or repairs.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #7 of 10 Old 02-23-2019, 12:57 PM Thread Starter
Originally Posted by Shaw351 View Post
Hey cranman.....
Joe...you were the one that turned me on to them! It is still in the box.....plan is to put together a killer 32 in 924. I've been rebuilding a tractor section from an ST 1032, and have a 32 inch bucket to redo....lately I've been thinking to put a 28 inch bucket on it instead of the 32.Hard to find one in the 924 series though!
cranman is offline
post #8 of 10 Old 02-23-2019, 01:08 PM Thread Starter
Just an update....the 144cc Honda I put on the 1973 910018 Ariens had a coil issue I fixed yesterday, but I was disappointed in the power it had...so today swapped it out for the 208 cc. I had to shim the 25 mm crankshaft with a couple of pieces cut from thin aluminum flashing to accept the pulley, and the crank was a little long to use the stock belt shield so I cut 3/4 inch off. It was a simple quick swap. I added gas and fired 1st pull. It hunted on the governor with out choke until it warmed up, the was smooth. The idle is fixed and seem too low to throw snow effectively, but had plenty of power and threw wet slop at least 20 feet. I don't care for the fact it has no fuel shutoff, and will check out adding one. I have a similar snow engine for parts I'll see if I can swap out the carb and snow shield to. The ignition shut off is the little red "key " that you have to pull out to ground out the coil, which I can live with and the throttle being fixed isn't a big deal. This little girl is going over to my girlfriends house to be her 2nd blower.
Name:	208cc 74 Ariens 001.jpg
ID:	154021   Click image for larger version
Name:	208cc 74 Ariens 002.jpg
ID:	154023   Click image for larger version
Name:	208cc 74 Ariens 003.jpg
cranman is offline
Thanks SimplicitySolid22 thanked for this post
Likes SimplicitySolid22 liked this post
post #9 of 10 Old 02-23-2019, 02:43 PM
Thanks (Given): 63
Likes (Given): 77
Cran that engine looks bigger than I thought it would...Thanks for the update!
post #10 of 10 Old 02-23-2019, 03:09 PM Thread Starter
SS22...all in all, well worth the $79....I've got a few 10000 series Ariens needing motors...unfortunately I don't think I can get much for one even when gone through and repowered. Even the twin sticks are getting hard to sell for a price that makes it worth while to refurb.
cranman is offline
Similar Threads
Help! Stuck! Repowering a Honda with a predator engine Matt Honda HS520ASA Snowblower Repairs and Maintenance Forum 41 01-11-2018 09:32 AM
need to know the maximum engine speed Markus (DE) MTD Snowblowers 2 02-09-2015 04:35 PM
Just got a 624 and have some questinos TomB985 Honda Snowblowers 137 02-25-2014 09:37 PM
International Cadet 265 problems NDbrewer Snowblower Repairs and Maintenance Forum 64 02-05-2014 11:45 PM
Tecumseh Engine Replacement gsnod Snowblower Repairs and Maintenance Forum 28 01-07-2014 01:52 PM
