Tecumseh lh318sa replacement - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-19-2019, 02:10 PM Thread Starter
Hi Folks!
I've done some pretty thorough searching but I still can't find any leads on a replacement for my Ariens 926le 926001.
It has the original Tecumseh lh318sa engine, which is running fine but bogs down more then I think it should. I'm just curious as to what is out there for replacements.
Side note, I do have a few other threads regarding the bogging issue. I have replaced the carb, and have clean fuel. Plug is new too. Throttle opens all the way when it needs too. Compression is at 80psi with electric cold start.
Again, just curious about other engines. However any other ideas about the bogging issue would be great. I did have a ariens 724 form around 2001. I don't recall it ever bogging down like this one. I traded up for the 926 due to anew house with a much longer driveway.
Harry Doyle is offline
post #2 of 10 Old 02-19-2019, 07:36 PM
Thanks (Received): 98
Likes (Received): 260
Your compression seems too low. Anyone else feel that way ?
RIT333 is online now
post #3 of 10 Old 02-19-2019, 07:48 PM
Thanks (Given): 176
Thanks (Received): 344
Likes (Given): 481
Likes (Received): 850
My 318cc OHV Tecumseh gave 80 psi with the electric starter. I'd just gone through and checked the bore, replaced the head gasket, and adjusted the valves. So it doesn't seem bad to me, with my limited experience.
post #4 of 10 Old 02-21-2019, 08:08 AM Thread Starter
Hi Folks
I'm still looking for recommendations for a replacement engine. Looks like I can't get the original Tecumseh lh318sa.
Thanks!
post #5 of 10 Old 02-21-2019, 08:51 AM
Thanks (Given): 176
Likes (Given): 481
You might be able to get a used Tecumseh 8hp for cheap. They were used on a ton of machines. Might even be cheaper to buy a junky machine with a good engine, than just an engine.
If you want new, the Predator engines are popular for re-powering. Though the $100 212cc might be a step down in power. The 301cc (?) Predator will be substantially more powerful, but is over $200, I think.
post #6 of 10 Old 02-21-2019, 11:37 AM Thread Starter
Thanks. Are the predator engines reliable? I'll look into them. My Tecumseh is 9hp 312cc
post #7 of 10 Old 02-21-2019, 11:43 AM
Likes (Received): 280
Yes - those are very good engines really. Can't beat 'em for the price.
post #8 of 10 Old 02-21-2019, 01:27 PM
Thanks (Received): 212
Likes (Received): 767
I'm on over 12 years with the earlier version of the Predator......no issues at all. Look into repowering with a 12 hp Tecumseh...just a bolt on swap and plenty of ooph
cranman is offline
post #9 of 10 Old 02-27-2019, 07:10 AM Thread Starter
Can the auger gear box handle 3 more hp?
post #10 of 10 Old 02-27-2019, 10:08 AM
Should be no problem....but before you go to the trouble...try adjusting your governor..or at least checking to see if it works. donyboy and Taryl have great videos on how to.....
cranman is offline
Similar Threads
tecumseh - honda replacement AL- General Snowblower Discussion 3 01-07-2019 11:01 PM
Tecumseh replacement carb cathey Snowblower Repairs and Maintenance Forum 6 12-30-2018 08:19 PM
Direct replacement for Tecumseh LH195SP engine? chrispyny Re-Powering 12 01-04-2018 11:11 PM
Ariens 8526 with Techumseh LH318SA needs replacement options ekg_80 Ariens Snowblowers 8 02-15-2015 05:21 PM
Tecumseh Engine Replacement gsnod Snowblower Repairs and Maintenance Forum 28 01-07-2014 01:52 PM
