Toro 724 Tecumseh -> Predator 212 - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 03-09-2019, 12:33 AM Thread Starter
My '87 Toro blew its original engine over a month ago. I bought it last summer for $150. It would only ever run with the engine choked but it was usable. Would bog down in anything over 4" of powder but I got used to it.
I picked up a Predator 212 at Harbor Freight and got it in place on the frame. I had to drill some new mounting holes to align it properly. Also had to buy a crankshaft bushing. I scrapped all the wiring off the handlebars and installed a tether/kill switch but there's a short somewhere. Neither the kill switch nor the on/off switch will stop the engine now. I'll tackle that later.
When I first started it up it didn't want to run above idle so I figured the main carb jet was too big. I live at 6000' elevation so I figured it was drowning in fuel when I couldn't rev the engine without stalling it. The power chart for Honda says for every 1000' above sea level you lose 3.5% power if I remember right. So I did some math and figured I need a .023-.024 jet.
I ordered a high performance jet kit by mistake and tried messing with the two jets that came with it. I soldered them closed and tried drilling one out but buggered that job. I didn't have the correct size drill bits at the time. I tried using wire from a wire brush, tried a paper clip. Nothing worked. I ended up getting a set of #61-80 drill bits from Rockler to make the jet drilling easier.
I found some .026 (stock is .0307 or #78) Honda jets at gokartsusa.com. It seemed the most reasonable deal I could find. Not happy with the delivery time but they finally arrived. I was disappointed at first because they appeared to be stainless and not brass. I didn't believe I would be able to solder or drill them out if I needed.
This morning I took some time to monkey with the engine. I installed a soldered jet drilled with a #73 bit and started up the engine. It idled beautifully but was hunting pretty bad at high rpms. So I took started stepping up sizes with the other jets. To resize a carb jet it was very easy to place a jet in my cordless drill chuck and hold the small drill bit with a pair of pliers, using the cordless drill as a lathe and the pliers as the tool holder. The gray metal Honda jets drilled like butter.
I stepped through each size of bit all the way to #65 (larger than stock) before I finally got the engine to quit hunting and run just a little rich at high speed. Its not super smooth at high rpms, stumbles a little, a little dark exhaust, and doesn't truly smooth out unless I back the throttle off to 70-80%. Then it runs great. I don't understand how I ended up with such a large jet orifice when the stock jet wasn't working well. Sometimes it goes lean at full throttle and starts hunting again. Is there something else I can do to improve the air/fuel ration? I tried pulling the airbox cover but didn't notice a change. I did not pull the air filter and the vents from the valve cover and gas tank are still in place.
I haven't put it too work yet. It looks like we're getting some light snow tonight so I might try it tomorrow.
Leavitt is offline
post #2 of 2 Old 03-11-2019, 06:42 PM
Likes (Received): 14
I’d try pulling the air filter off all together.
LB522r is offline
Similar Threads
Honda HS720C vs Toro 721QZR BMR General Snowblower Discussion 16 10-29-2014 10:28 PM
Ariens 24 vs. Toro PowerMax 724 ? Spokaneman General Snowblower Discussion 17 11-23-2013 02:29 PM
Toro Customer Service moretorque05 Toro Snowblowers 2 11-15-2013 05:22 PM
Toro with Tecumseh AH600 bwdbrn1 Toro Snowblowers 2 10-04-2011 08:24 AM
