Troy-Bilt 8/24 re-power - Snowblower Forum : Snow Blower Forums
post #1 of 44 Old 03-15-2019, 05:01 PM Thread Starter
Likes (Received): 17
I picked up a an older Troy-Bilt 8hp 24Ē model 42010. Previous owner said it has very low hours and it shows. Very clean machine for its age. I posted a pic in another thread and thanks to this forum, you guys noticed it actually had an older 7hp Tecumseh engine.
The engine had trouble starting but got i got it going eventually. It runs a bit rough and noticed it was leaking oil. Since the machine is in great shape and built like a tank, i want to re-power it.
I was looking for an 8hp engine but got a great deal on a Predator 420cc. I know this is a lot of power for a 24Ē blower but itís pretty much in the same category as my Ariens SHO 24Ē 369cc which is a beast. That machine is used at my commercial property.
Comparing the specs of the current Tecumseh engine thats on there now the the shaft height on the Tec is 4.1Ē (if iím correct) from the mounting plate to the shaft vs. 5.26Ē on the Predator. What size belts will i need?? I tried to look up the current belt size so i would have some idea but had no luck. Any ideas? Thanks!
Troy-Bilt 8/24 re-power-img_2208.jpg
2015 Ariens Platinum SHO 24" AX369 | 1995 Troy-Bilt 8/24 w/ Predator 420cc
PB617 is offline
Likes eyebolt liked this post
post #2 of 44 Old 03-15-2019, 05:22 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 285
i could be wrong but i feel like a 420cc 13hp on a machine that size is overkill. i would maybe shop around for a 250-300cc.
as far as belts go you almost need to swap the new engine on so get an idea what size you need.
yardworks 31AH6WKF515
crazzywolfie is online now
Thanks PB617 thanked for this post
post #3 of 44 Old 03-15-2019, 07:45 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
Even the 301cc would barely bog down with a full bucket of snow.
420cc is way to big for its current gearing. I say use the 420 but bump the auger drive pulley by an inch minimum and install an impeller seal kit. It’ll be a monster.
drmerdp is offline
post #4 of 44 Old 03-15-2019, 08:14 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
What is the OD on the auger pulley portion of that pulley? You could probably go up to 3.25" or 3.5" comfortably.
(On my GX390-equpped 9240404, I'm running a stock Ariens 924 series dual pulley which is 2.75" for the auger belt and 2.5" for the drive belt. I'm planning to go up to 3.25" for the auger belt)
Once you have the engine installed, you'd probably need to use a piece of string to determine the needed belt size.
db130 is online now
post #5 of 44 Old 03-15-2019, 10:04 PM Thread Starter
Thanks for the info guys. This is my first re-power so iím sure iíll have more questions. Iím going to remove the old engine this weekend and bolt up the predator for measurements.
Iíll measure the pulleys that are on there now.
PB617 is offline
post #6 of 44 Old 03-16-2019, 12:30 AM
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
You might not have to adjust to much... they put a Riser mounting plate under that Tec...So if you remove the TEC. engine and the riser plate and just mount predator you might be close with the belts!!!! So before you remove the tec try to get some type of measurement from center of the engine PTO shaft to where bottom of riser meets body of TB(base). Then when you bolt up the predator with out riser....you might be close in belt measurement. Just thinking...???
I always thought Tec's(hence need for riser on TB) were 4.25 and Briggs were 5.25.....PTO height. Your belts might already be adjusted to 5.25height due to riser so Predator might fit just right without riser. Ok I am Ramblin' at 12:30am...Let us know how you make out!
Not sure If your engine sheave is 3/4 or 1" but that might be an issue???
SimplicitySolid22 is offline
post #7 of 44 Old 03-16-2019, 11:04 AM Thread Starter
I donít think there is a riser plate on mine. I donít see one. I didnít think i would have to change so much lol.
The engine sheave is 1Ē on both the Tec and the Predator.
PB617 is offline
post #8 of 44 Old 03-17-2019, 12:13 PM
Thanks (Given): 63
Likes (Given): 77
Thumbs up 1"!!!
post #9 of 44 Old 03-17-2019, 12:20 PM
Thanks (Given): 63
Likes (Given): 77
I know on Bolens equivalent 824 they use one for the Tec! Maybe a different setup???
post #10 of 44 Old 03-17-2019, 01:15 PM
Thanks (Given): 16
Likes (Given): 241
I've never seen a riser on any Bolens 24" snowblower.
db130 is online now
Similar Threads
Issue with Reverse Gears on brand New Troy Bilt ekeenan81 Troy-Bilt Snowblowers 14 12-24-2019 12:32 AM
2410 Troy bilt not running right Jrdriver Snowblower Repairs and Maintenance Forum 4 01-27-2019 01:25 AM
Modified Troy Bilt in Ct CTtroybilt New Member Introductions 28 12-12-2018 09:21 AM
Troy Bilt blowers at Home Depot? Blosumsno General Snowblower Discussion 9 08-27-2018 01:38 AM
FINALLY added lights to my Troy Bilt!! PICS!!! Ant2410 General Snowblower Discussion 12 12-04-2012 08:38 PM
