Honda GX340/390 on Ariens 10000 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 04-11-2019, 08:31 AM Thread Starter
Thanks (Given): 29
Likes (Given): 33
Likes (Received): 10
So I know the Predator engines are Honda clones, but I've come across a GX340 11 hp to replace my Tecumseh HMSK100 for my 32" Ariens and I'm A) not sure if it's worth it, and 2) if it is, is it a direct bolt on or would this require any additional fabrication? I can't seem to find information on GX bolt patterns and spacing to compare to the HMSK engines.
WalkThisWhey is offline
post #2 of 13 Old 04-11-2019, 11:18 AM
Thanks (Given): 202
Thanks (Received): 126
Likes (Given): 416
Likes (Received): 266
Take the Honda over the predator, much better engine. The bolt hole spacing are usually universal standard chassis size for engines of specified chassis size, meaning the Tecumseh is a "medium" chassis. Most of your medium chassis bolt hole spacing's are the same. They have small, medium, and large chassis size spacing's for different sized engines.
ST1100A is offline
post #3 of 13 Old 04-11-2019, 02:07 PM
Likes (Received): 280
The main problem might be the shaft diameter.....? Not sure they are "easy" depending on which one is bigger...... hopefully the Honda is smaller. In which case you can simply sleeve it. I have done that with a chunk of EMT conduit before and it worked out well. (had to cut a slit for the key of course)
post #4 of 13 Old 04-11-2019, 02:31 PM Thread Starter
Thanks (Given): 29
Likes (Given): 33
The one I am seeing is a 1" shaft, and my current pulley is that too.
post #5 of 13 Old 04-11-2019, 03:04 PM
The honda will be metric I'm sure... but you may also need a belt depending on how much offset it has compared to the old one. Either way, you will like how much smoother it runs! Those Honda's are tough to beat! I put one on my Craftsman and that thing is beautiful. I'm looking at doing the same thing to my tiller this year......
post #6 of 13 Old 04-11-2019, 04:25 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
If it's a 1" crank, then it's a general purpose engine, like from a pressure washer.
You will need to drill new holes on the Ariens as the GX engine block is significantly larger and you will likely need a different belt cover, as the crank height is higher on the GX as well.
I have a GX390 installed on a 924 series, and here are the holes I had to drill:
db130 is offline
Thanks WalkThisWhey thanked for this post
Likes WalkThisWhey liked this post
post #7 of 13 Old 04-11-2019, 05:12 PM
Thanks (Received): 212
Likes (Received): 767
This will be a great swap....
cranman is offline
post #8 of 13 Old 04-11-2019, 06:07 PM
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
For GX390 it is 7.70" on center left to right and 4.1" front to back. Two of the base holes are slotted (0.7)(1.1).
One of the SBFer's just offered engine manual from Gx240 to 390 and it has engine schematics.
Same dimen. for 340!!!
SimplicitySolid22 is offline
post #9 of 13 Old 04-11-2019, 06:55 PM
Thanks (Given): 63
Likes (Given): 77
Tabora was very nice to offer Honda manual on 03/25/2019.....if you want to look back.
post #10 of 13 Old 04-11-2019, 07:19 PM
Thanks (Given): 348
Thanks (Received): 107
Likes (Given): 1068
Likes (Received): 188
Tabora's post:
https://www.snowblowerforum.com/foru...ml#post1664439
PDF manual direct link:
https://www.wincogen.com/wp-content/...0-GX340_SM.pdf
Honda HS828TAS (1991) – Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) – Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is offline
Similar Threads
Buying advice: 28" Cub, Ariens, Honda? mgvrmark General Snowblower Discussion 33 03-10-2019 11:53 AM
Trade Ariens Hydro Pro 36” for Honda 928 or 1132 Macplee Snowblowers and Snowblower Parts for Sale 15 01-26-2019 11:15 AM
Please help me decide : Honda 928 or 1332 vs Ariens Pro 28 or 32 Blepski General Snowblower Discussion 50 09-12-2017 10:20 AM
Ariens Platinum 28 or Honda 928? Advice needed Ron in PA General Snowblower Discussion 12 04-06-2017 10:11 AM
Honda Snowblowers and Gravel Driveways: McRockFish Honda Snowblowers 82 08-23-2016 03:04 PM
