are there winter-ready Predator 212cc anymore? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 09-11-2019, 04:17 PM Thread Starter
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
I am looking to re-power my 1995 Toro 724 and have been looking online at the Predator 212cc, but can't find any that are winter-ready. Do those exist anymore?
Paul
paulm12 is online now
post #2 of 8 Old 09-11-2019, 04:27 PM
Thanks (Received): 212
Likes (Received): 767
On e-bay they still have winter ready 208cc clones for $79 free delivery. Only issue is they have 25cc shafts, a couple of thousandths less then 1 inch...can't get pulleys for. I've bought and tried two, and just shimmed the 1 inch pulley with shim stock...worked great.
cranman is offline
post #3 of 8 Old 09-11-2019, 04:30 PM Thread Starter
Thanks (Given): 63
Likes (Given): 277
I figured that you would know about this Cranman. So doe HF not make them anymore?
Paul
post #4 of 8 Old 09-11-2019, 09:03 PM
Thanks (Received): 150
Likes (Received): 543
I have the reg. 212cc Predator on one of my Ariens …. Here in CT it is no issue running that machine in the winter, been using it for 3 or 4 years now. Any machine that needs an engine, the 99.00 HF is the way to go for sure.
oneacer is online now
post #5 of 8 Old 09-12-2019, 03:39 PM
In over 20 years of running my ST 824 on a clone, only ONCE did I ice up the governor .......I'm a big fan if the HF Predator.....that said, the 79 dollar 208cc engine on e-bay, has a primer bulb and is a snowblower engine. Like I said, it has a 25mm shaft, but a coulple of pieces of .002 shim stock and the 1 inch pulley fit nicely.
cranman is offline
post #6 of 8 Old 10-31-2019, 01:49 AM
I just repowered 1980 Ariens 8/24 with a predator 212 in Minnesota I haven't used it yet. Question: ... Im afraid the predator will get cold (prob in the air intake while running) should i i make an exhaust reflector to cycle the heat back thru maybe to the airbox? im running 5w to help with the cold.
cheers I have tons of questions...but Its all assembled and purrs after the break in period
tylanway is offline
post #7 of 8 Old 11-11-2019, 04:15 PM
Thanks (Given): 8
Likes (Received): 29
To winterize my Predator I did the following:
Remove the air filter and replace it with a metal screen.
Up the main jet size to around .034
Remove the check valve from the tank vent and drill out the restriction.
Replace the junk factory spark plug with an NGK.
Optional:
Install a manual throttle control
Install a battery powered tachometer/hour meter.
Move the governor spring over one hole to up the RPM a bit. Try to stay under 4000 RPM.
PredaToro: Toro 521, Predator 60363
yoda is offline
Thanks paulm12, Sblg43 thanked for this post
Likes Sblg43, Kiss4aFrog liked this post
post #8 of 8 Old 01-12-2020, 07:49 AM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to SBF tylanway
Have you had a chance to take it out in the snow yet ?
