Just in case ...... - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-12-2019, 09:24 AM Thread Starter
Thanks (Received): 149
Likes (Received): 540
Just in case ......
I came across this in case it may assist anyone in doing a repower.
At 25.00, it would save a lot of head ache, especially for someone that does not have the ability to weld.
Mount-BS-Tec Briggs & Stratton Gas Engines, Horizontal - Engine mount plate, 1/8" thick, to replace Tecumseh HM80-HM110, LH318-LH358, OHM120, OH358SA, OHSK120, OHSK125, OHSK130 with Briggs Intek model "20" and "21" engines, primarily on snow blowers.
oneacer is online now
Thanks cranman, Kiss4aFrog thanked for this post
Likes Grunt liked this post
post #2 of 9 Old 11-12-2019, 09:41 AM
Thanks (Received): 212
Likes (Received): 767
Would that be the same bolt pattern as the 414 LCT?
cranman is offline
post #3 of 9 Old 11-12-2019, 09:50 AM Thread Starter
My guess would be contact LCT, find out there bolt pattern and match it.
Here is the plate mod specs:
http://www.smallenginewarehouse.com/...8afa2459752d3a
post #4 of 9 Old 11-12-2019, 10:09 AM Thread Starter
@cran,
Near as I can tell, the 414cc winter engine by LCT is close, at 103mm (4.05") X 195.5mm (7.69") bolt pattern …. you might want to double check that.
Source I pulled those numbers from:
https://www.powerequipmentdirect.com...b90817bafe.pdf
post #5 of 9 Old 11-12-2019, 10:32 AM
Thanks oneacer...looks to me like it's just enough off to make life difficult......I'll try my hand from scratch....
cranman is offline
post #6 of 9 Old 11-12-2019, 11:35 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Cranman as we both need one I have a few ideas, I need to check a few measurement and fill you in when Iím out of work.
Dauntae is offline
Thanks cranman thanked for this post
post #7 of 9 Old 11-12-2019, 12:04 PM
sounds good Bruce
cranman is offline
post #8 of 9 Old 12-03-2019, 12:44 PM
Just at quick glance looks like this would move a Predator forward to deal with the short shaft.
michics is offline
post #9 of 9 Old 12-03-2019, 12:54 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I made up a couple of drawings when I repowered my ST1032 with an LCT 414cc engine, to help line the mounting holes up. One puts the crankshaft in the same place, but the LCT mounting is so wide that the mounting holes on one side are right at the edge of the top of the tractor housing. The other drawing fixes that - it offsets the engine a little to the side.
I was going to attach them to this point but the site says they're too large even though they're only about 100KB each. But if anyone's interested, PM me your email address and I can send them to you. If they're right for your engine, you can actually print them at 1:1 scaling and use them to mark mounting hole locations.
ELaw is offline
