Smart People of the Internet, your thoughts on an Engine Swap ST824? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-04-2019, 08:46 AM Thread Starter
I blew the rod in my engine during the storm yesterday... I heard the ping ping and knew I should have stopped right then and there but said to myself, just one more pass and I am done... well.... now, I am done... as the rod broke through the sidewall of the engine....
I have an Ariens 924050 028860 which has engine HM80 155128F
I found a used 924082 048855 which has engine HMSK80 155526S with a busted Auger/Gearcase
It looks like I can't just swap the 24" blower units, but I may be able to swap the engines, where the engine sheave is the same size.......
When it comes to engines, I know just enough to be dangerous, curious to learn if this is as simple as it sounds inside my head....
TommyRockz is offline
post #2 of 10 Old 12-04-2019, 08:58 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 459
Upgrade for $100, buy a Harbor Freight Predator 212cc engine.
JLawrence08648 is offline
Likes gsnod liked this post
post #3 of 10 Old 12-04-2019, 08:59 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'd say 99% likely the answer is "yes". HM80 and HMSK80 are pretty much the same engine - the "SK" bit means "snow king" which is an engine specifically made for snowblower applications.
ELaw is offline
post #4 of 10 Old 12-04-2019, 09:09 AM Thread Starter
I like the idea of a new engine... I see other posts tied to the predator, it seems the difference in HP isn't an issue... and the only key difference is the shaft....
That just might be the way to go...
post #5 of 10 Old 12-04-2019, 09:14 AM
Thanks (Given): 96
Likes (Given): 75
The pulley on the Predator is 3/4", the Tecumseh 8hp is 1". You'll have to get a new pulley for the Predator.
post #6 of 10 Old 12-04-2019, 09:20 AM Thread Starter
Yes, thank you for the note, I am reading through the forum and found the ebay link to the shaft sleeve.... as well as a link to a Super Coupon that brings the Predator engine down to $99 like you said....
You have to wonder... how they can assemble an engine... ship it across the world... stock it in the store for $99....
post #7 of 10 Old 12-04-2019, 09:29 AM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
Shaft adapter to use original pulley, $10https://www.ebay.com/itm/New-3-4-to-1-inch-w-Step-Key-Gas-Engine-Crank-Shaft-Sleeve-Adapter-Predator-1/163435999396?hash=item260d8b70a4:g:fkoAAOSw2Xdd4Lu p
Jackmels is offline
post #8 of 10 Old 12-04-2019, 09:36 AM
1132le's Avatar
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Not all hm80 are 1 inch shaft
1132le is online now
post #9 of 10 Old 12-04-2019, 09:39 AM
1132le's Avatar
Likes (Given): 68
Downgrades for using the predator
No elec start
not a winter engine has no carb box
less power
not a bolt on
Likes Ian Ariens 924 liked this post
post #10 of 10 Old 12-04-2019, 06:04 PM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Are you sure that the buckets don't interchange?
I've picked up a 924050 for parts before:
https://www.snowblowerforum.com/foru...57-post28.html
I've also done a 212cc swap on a 924082:
https://www.snowblowerforum.com/foru...545-post1.html
The part numbers may be different, but I think they may be interchangeable.
db130 is online now
