MTD Tecumseh trying to repower with Predator 212 - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-08-2020, 03:04 PM Thread Starter
As the title says i’m trying to repower my MTD single 7/8 shaft with a predator HF engine that so many others have done. I am having a **** of a time figuring out how to make the pulleys work. I’ve purchased a 7/8 sleeve adaptor and the keyway for the original pulleys only lock that. I can’t figure out how to lock the sleeve from spinning on the shaft. Any others want to chime in if they’ve accomplished the similar project on a single shaft 5hp
Dan55106 is offline
post #2 of 8 Old 02-08-2020, 03:48 PM
GustoGuy's Avatar
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
I would simply get new pulley's. I didn't bother using the original Tecumseh pulleys when I repowered my MTD. The Predator 212cc has a 3/4th inch keyed shaft and you can put a 3-inch pulley on the top to increase the impeller speed. Since it is a single shaft engine it will be much easier to do than my double shaft MTD5/22 was.
GustoGuy is offline
post #3 of 8 Old 02-08-2020, 05:38 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3333
Likes (Received): 679
Welcome to SBF Dan. I'm guessing that your original MTD pulleys have the key molded into the pulleys and they are not high enough to go through the shaft adapter and into the crankshaft. If so, the easiest way would be to buy two new 3/4" pulleys with "key ways" to fit over the crankshaft key as Gustoguy suggested.
post #4 of 8 Old 02-08-2020, 09:52 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
As others have said, you will have to get aftermarket pulleys. If the drive pulley is 2in in diamter, get an AK20, for a 3/4 shaft and the auger drive is approx 2 3/4, get an AK27 pulley. Also, get some key stock, and make a long key for the shaft.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #5 of 8 Old 02-09-2020, 11:05 AM
Thanks (Received): 212
Likes (Received): 767
Tractor supply has a selection of pulleys
cranman is offline
post #6 of 8 Old 02-09-2020, 01:38 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4352
Likes (Received): 1734
to SBF Dan
to the re-power section.
Many different sources for a proper pulley.
https://www.ombwarehouse.com/search....ection=product
https://www.mcmaster.com/v-belt-pulleys
https://www.grainger.com/category/po...v-belt-pulleys
https://www.fastenal.com/product/pow...sExpanded=true
Amazon, Ebay and most big box and hardware stores.
post #7 of 8 Old 02-10-2020, 04:33 PM
Thanks (Given): 33
Thanks (Received): 65
Likes (Given): 115
Isn't the shaft to short on some of the predator repowers.. and people take advantage of the length of the sleeve? ..to make up the difference.
Or at least a long outside pulley just to be sure
Shovel is offline
post #8 of 8 Old 02-27-2020, 11:04 PM
Dan55106 curious what you ended up doing.
Here is a link to what I did. I think the MTD and the Craftsman are basically the same.
https://www.snowblowerforum.com/foru...r-repower.html
Herb
burt8810 is offline
