3 hp dynamark snow thrower - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-24-2020, 07:04 PM Thread Starter
Good day- I bought a non running 3hp dynamark snow thrower. After some checking, my suspecion was correct. The carb was clogged with old oil from the 2stroke gas that was left in it.
It will run for a couple of seconds on ether. I pulled the carb and the bowl was full of old gas and oil. I drained the tank and replaced it with fresh gas oil mix. I soaked the carb in cleaner and blew it out. It still will not run more than a few seconds on ether.
I cannot tell what the brand of the motor or carb is in order to buy a new carb for it. I've done some research but cannot come up with a carb part number. There are several on eBay for 3 hp motors, how do I know which is the correct one? Any help is appreciated. I can post a pic of the snow thrower if I can figure out how
semerm12 is offline
post #2 of 5 Old 03-24-2020, 07:13 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
How long did you soak the carb in cleaner?
If there's a long narrow passage that's clogged with "guck", it may take quite a while for the cleaner to get in there and dissolve it. Many hours, or even days.
Also pics of the snowblower would probably help, as well as pics of the engine. And any model # info for the machine and engine.
ELaw is offline
post #3 of 5 Old 03-24-2020, 07:34 PM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 745
Likes (Received): 266
semerm12 welcome to the sbf.
it would help if you could post the model and first few of the serial number for the members to better help you
87powershiftx2 is offline
post #4 of 5 Old 03-25-2020, 02:36 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post....Welcome to the SBF from Gettysburg address
2019 Ariens Compact 24...
penna stogey is offline
post #5 of 5 Old 03-25-2020, 08:01 AM
Thanks (Received): 14
Likes (Given): 36
Likes (Received): 28
It's likely a Tecumseh . There are tons of Tecumseh 3hp, Powerlite, Tec 98cc carbs on Ebay or Amazon for cheap.
Follow your green wires from the key switch, one will go behind the cowling and one is attached to the outside of the recoil housing. You should notice the engine model sticker around where that wire is attached. (HSK600 or TH098SA)
oneboltshort is offline
