Re-powering My Ariens Sno Thro 6 HP - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-19-2015, 01:57 PM Thread Starter
Hello Folks.
My old Ariens Sno Thro with a Tecumseh 6 HP Snow Blower is burning oil, leaks fuel and stalls. I think it's time for my snow blower to receive a new heart.
Here is one on Ebay that I am considering. This motor has a pull start only.
What do you think?
Richard
7HP Tecumseh Snow King Engine OHV Horizontal 3 4"X2 5 16" Shaft OH195SA 72536 | eBay
Snow Job is offline
post #2 of 14 Old 02-19-2015, 04:22 PM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
A hundred $ harbor freight worked for my 1968 ariens. Sadly it's probably a better engine
Rob711 is offline
Thanks GustoGuy, gsnod thanked for this post
Likes gsnod liked this post
post #3 of 14 Old 02-19-2015, 04:53 PM
Likes (Received): 42
If you want a cheap, easy fix, the Harbor Freight option is hard to beat. However, none of your current engine's ills appear terminal terminal. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #4 of 14 Old 02-19-2015, 05:38 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
If you want to re-power you have a good reason but rebuilding or replacing the carb would likely take care of the leak and stall and you could do the engine this summer if you chose to.
post #5 of 14 Old 02-19-2015, 05:41 PM
i would go with the predator, you can get one for around $100 and they are more reliable and better built then any tecumseh. lets not make this into another engine brand bash thread, lets just help the guy
Thanks GustoGuy thanked for this post
post #6 of 14 Old 02-19-2015, 05:44 PM
Thanks (Given): 30
Thanks (Received): 40
Repower with a Predator can be done "over the weekend" and up and running. I think it's much quicker if you only have the one machine to use.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #7 of 14 Old 02-19-2015, 05:48 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
What about the oil burning? I had an 8hp Briggs that would eventually foul it spark plug and puffed blue smoke once in a while while it was running. Most likely valve guides. Right now I have a Predator 212cc sitting on the snow blower and it works great.
This is a video of it blowing snow. This is a 26 inch Montgomery Ward (Gilson) unitrol machine
GustoGuy is offline
post #8 of 14 Old 02-19-2015, 06:17 PM
Thanks (Given): 591
Likes (Given): 4374
Doing the carb is quick, simple, plenty of how to videos and fairly cheap. Keeps the machine in the game for now. Could even buy a new one. Doesn't solve the oil burning but the leaking fuel is my big concern.
As we all know to cure the burning it might be a clogged breather or guides or rings that are likely just old and worn. Either you want to keep that engine since it "fits" and you rebuild with rings or replace. Some people don't have the room, time or skills to do a motor swap. I'm just offering alternatives.
post #9 of 14 Old 02-19-2015, 06:29 PM
This guy is in Canada. Princess Auto has the Power Fist 7HP snowblower engine he should look at as well.
post #10 of 14 Old 02-19-2015, 06:37 PM
in that case, get the 196cc powerfist, or this predator from ebay
NEW Predator Horizontal Shaft GAS Engine Shop 6 5 HP 212 CC L K | eBay
