engine replacement - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-01-2015, 09:39 PM Thread Starter
engine replacement
Hello, I'm looking to replace my blown briggs 900 intek engine on my 2007 simplicity 924i. I was wondering if a intek 1150 would fix with the stock pulleys and mounting holes. I believe they both are 3/4 Dia and 2 5/16" length shaft.
Doug12992 is offline
post #2 of 4 Old 03-01-2015, 11:09 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
Welcome to the forum
post #3 of 4 Old 03-02-2015, 01:54 AM
Thanks (Given): 30
Thanks (Received): 40
You say the shaft is size and length is the same, so all you need to check is the shaft height off the base and left/right position. I guess just download the manuals for the engines and do a quick compare on the diagrams and you will have your answer.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #4 of 4 Old 03-02-2015, 04:37 AM
Likes (Given): 1880
Likes (Received): 661
hello doug, welcome to SBF
