Two output shafts! Now What? - Snowblower Forum : Snow Blower Forums
post #1 of 33 Old 03-04-2015, 08:01 AM Thread Starter
Welcome from Massachusetts.
1996 Ariens ST724. Model 932027
Tecumseth motor gave up with big bang. Feels like no compression. No holes in case.
Started taking the motor off to order a new motor and found two output shafts. I looks like this blower is married to this engine!
What are my options. Is their a replacement engine?
BrokenAriens is offline
post #2 of 33 Old 03-04-2015, 08:04 AM
you can flip the transmission
post #3 of 33 Old 03-04-2015, 08:16 AM
Thanks (Given): 7
If your cam and cover are still good, transfer them over to a different HSK70
HillnGullyRider is offline
post #4 of 33 Old 03-04-2015, 08:17 AM
Thanks (Given): 173
Likes (Given): 458
Likes (Received): 1036
Originally Posted by HillnGullyRider View Post
If your cam and cover are still good, transfer them over to a different H70
+1 on the transfer. Just unbolt and bolt to replacement engine..
post #5 of 33 Old 03-04-2015, 08:20 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Two-shaft engines are somewhat less common than single-shaft ones but they're not rare by any means... they're used on a lot of snowblowers.
I'd do some looking around C'list to see if you can find another engine like it. Or depending on how mechanically inclined you are, you could buy a single-shaft 7HP Tecumseh and swap the necessary parts from the old motor to the new one (I think the camshaft and end cover would do it).
Another option: just buy an older working snowblower off C'list. There are a lot of perfectly good ones on there for the same or lower price as a brand-new engine.
ELaw is offline
post #6 of 33 Old 03-04-2015, 09:42 AM Thread Starter
Checking craigslist.
post #7 of 33 Old 03-04-2015, 12:16 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
If you add a location to your profile it will pop up with your posts and maybe somebody in your area might see a twin shaft on Craigslist and let you know.
Good reason to add location to profile.
post #8 of 33 Old 03-04-2015, 03:41 PM
Thanks (Received): 17
Likes (Received): 79
does it look like this one ?
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #9 of 33 Old 03-05-2015, 07:28 AM
Thanks (Received): 35
Likes (Received): 81
If there are no holes in the case, why not open it up and see if the crank is still ok. If so replace the probably broken rod and your back in business.
CarlB is offline
post #10 of 33 Old 03-05-2015, 08:14 AM
Thanks (Given): 589
Likes (Given): 4364
6hp dual shaft
Tecumseh 6hp snow blower engine
