Belt guides? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 03-06-2015, 12:59 PM Thread Starter
Thanks (Given): 15
Likes (Received): 14
Belt guides?
The Tecumseh single shaft engines typically have one or two belt guides to keep the auger belt from slipping off the pulley when disengaged. They attach to the front of the motor. How do you guys deal with this on a repower?
Craftsman 5/22 with impeller mod & poly skids,
Ariens 28+ Deluxe 921037 AX291
Dave C is offline
post #2 of 8 Old 03-06-2015, 04:54 PM
Thanks (Given): 591
Thanks (Received): 772
Likes (Given): 4374
Likes (Received): 1743
Havent done one but . . . You could try running it without at first and see if you have a problem or you can make something up and use the engine mounting bolts as a fastening point if there isn't anything you can use on the face of the engine.
Maybe someone who's fabricated something will jump in this evening.
post #3 of 8 Old 03-06-2015, 06:39 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
No problems reusing the old belt guides if you go with the 212cc Predator:
db130 is offline
Thanks Dave C thanked for this post
Likes Kiss4aFrog, gsnod liked this post
post #4 of 8 Old 03-06-2015, 09:59 PM
I needed longer bolts and standoffs (or a stack of washers) under the original U shaped guide as the block of my repower was about 3/4 inch further away from the pulley position than my old motor.
Rockadode is offline
post #5 of 8 Old 03-06-2015, 10:01 PM
Thanks (Given): 10
[QUOTE=db130;563081]No problems reusing the old belt guides if you go with the 212cc Predator:
Agreed. Mine worked as well. I may have had to replace the bolts that fastened the guide, but the itself worked just fine.
Saewoody is offline
post #6 of 8 Old 03-06-2015, 10:24 PM
Thanks (Received): 40
Likes (Received): 149
Usually you can adapt something around the holes provided, it will take some fabricating. I have also seen owners build chassis up stanchions to support the guide(s) or idler roller arm.
Pete
Spectrum is offline
post #7 of 8 Old 03-07-2015, 10:42 AM Thread Starter
Thanks (Given): 15
Cool. Thanks.
Dave C is offline
post #8 of 8 Old 03-07-2015, 11:05 AM
Thanks (Received): 35
Likes (Received): 81
be careful not to use bolts that are too long as you will punch a hole in the back of the front cover. While not the end of the world, you may experience an oil leak around that bolt. If so just put some teflon tape on the threads, but it's best to make sure you have the correct length to start with.
I have used both the 6.5 and the 11hp harbor freight engines and have been able to use the original belt guides on all of them.
CarlB is offline
