Murray Repowering - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-11-2015, 03:14 AM Thread Starter
Murray Repowering
So all this repowering section is kinda of interesting. My old gas blower single stage with a tecumseh snowking is done. Over revved, and the block is cracked, and bearing shards with it.
Anyways, before I decide to purchase a new one for next season, can single stage motors (2-cycle) be re-purposed with a predator from HFT? any previous successful attempts?
murray21 is offline
post #2 of 6 Old 03-11-2015, 03:29 AM
Thanks (Given): 30
Thanks (Received): 40
Welcome Murray. Hope I got the situation straight.
Are you saying you have a 2 stroke that bit the dust on a small single stage machine and you want to put on a 4 stroke HF Predator to replace it, in the 2 stroke chassis ?
If I assumed the correct question, I would say No, won't work.
Reason being is that the 2 stroke machine chassis mounts the engine differently, and at an angle. The 4 stroke engine will not operate in this position. It will be starved for oil. The newer 4 stroke single stage machines mount the engine flat level just like a two stage machine, the lower part of the chassis is different than a 2 stroke single stage chassis. The 2 stroke engine will operate slanted, they just made a curved intake so the carb would end up level to accomodate the bowl/float.
Maybe you could look for a replacement on ebay
Just an idea.. good luck with it
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #3 of 6 Old 03-11-2015, 03:34 AM Thread Starter
Yup you got the situation right. I think i`m gonna scrap it and call it a day then on the ole murray.
murray21 is offline
post #4 of 6 Old 03-11-2015, 05:46 AM
Likes (Given): 1882
Likes (Received): 661
with all the toro, honda, murray, and mtd single stage snowblowers on CL it should be easy it get a replacement
post #5 of 6 Old 03-11-2015, 08:42 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
You are likely better off just posting yours on Craigslist in case someone has a good engine and broke something else on their machine and might be able to make one good one out of two and for you to just pick up another used machine.
post #6 of 6 Old 03-11-2015, 09:08 AM
Thanks (Given): 14
Thanks (Received): 28
Likes (Given): 19
Likes (Received): 21
Or just kick it to the curb and put it out with the trash. Someone will take it home only to find out the motor is junk. Just hope he doesn't discover the blown motor and return it to you.
____________________________
1989 Bolens 5210 R 21" - 5 hp 2 stage -- Impeller kit worked wonders
1983 Honda single stage -- HS 35 single stage -- still going strong
Prof100 is offline
