10HP Tecumseh Motor: Help ID these parts - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 05-10-2015, 04:27 PM Thread Starter
Likes (Received): 7
I bought this 10HP tecumseh to repower my 7/32 Ariens that is using oil.
I got the motor off CL and it starts and has good compression but I don't know what the odd electrical connection:
And this odd tube that appears to be a vacuum tube of some sort.
junkyard_sal is offline
post #2 of 7 Old 05-10-2015, 04:40 PM
Likes (Received): 483
The electrical connector seems to be a charging wire for a head light option.
The vaccum tube I believe is for the prime pump, it should be attached to the carburetor.
post #3 of 7 Old 05-10-2015, 06:44 PM Thread Starter
Likes (Received): 7
Thanks that was the ticket. I got it started but it would surge and not stay running once it got warm. It would stay running if I used the primer bulb. I guess the carb needs rebuilt.
post #4 of 7 Old 05-10-2015, 07:08 PM
[quote=junkyard_sal;626706]Thanks that was the ticket. I got it started but it would surge and not stay running once it got warm. It would stay running if I used the primer bulb.
You're welcome.
Some people use seafoam cleaner as an attemp to clean the carb (I've never done it).
If it still does not run right I would agre with a carb rebuild needed.
post #5 of 7 Old 05-10-2015, 08:28 PM
Also, in your first picture it looks like that bolt by the hanging wire is loose.
post #6 of 7 Old 05-11-2015, 10:11 AM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3367
Likes (Received): 683
The Sears engine number, 143.94001 translates to Tecumseh engine model HMSK100-159244T, in case you have to look up replacement parts.
post #7 of 7 Old 05-12-2015, 01:35 AM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
On the primer line you can just cut off the end if it's still long enough and put it back on the carbs nipple. When it's too short to trim then you have to pull the recoil cover and run a new line from the back of the bulb. That or if you can find something the right size you can splice in a couple inches and you're good. It's always the carb end where gas eats up the end of that vacuum line and makes it swell and or deteriorate.
