Repower Tecumseh single shaft to dual shaft - Snowblower Forum : Snow Blower Forums
post #1 of 34 Old 05-27-2015, 08:32 AM Thread Starter
Hello,
I have a John Deere 8/28 with a single shaft Tecumseh that has a broken connecting rod and I am having a hard time getting a replacement rod for a rebuild.
I wondered if a dual shaft Tecumseh could be used as a replacement and only use the main crankshaft drive?
I understand that either a 8hp or 10hp Tecumseh would fit the existing mounting arrangement but would appreciate clarification and/or comments.
I want to keep the 120V electric start option so I am not interested in a repower to another type of engine.
Thanks for your help.
VT JD is offline
post #2 of 34 Old 05-27-2015, 02:06 PM
It should work just fine as long as everything lines up. No need to use the extra shaft if you don't need it.
post #3 of 34 Old 05-27-2015, 03:08 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
The HF Predator 14Hp engine has a battery powered electric start option and some of the princess auto engines have an electric start option. If you already have a 2 shaft Tecumseh just do what Shryp says and only hook it up to the one shaft and you will be fine.
GustoGuy is offline
post #4 of 34 Old 05-27-2015, 03:12 PM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
Just a thought, those two shaft engines are getting harder to come by, maybe you could sell it locally.
Rob
Rob711 is offline
post #5 of 34 Old 05-27-2015, 06:00 PM
Likes (Received): 483
If you DO the repower, make sure that you install the pulley on the crankshaft, if you install it on the camshaft you will have only half the RPMs.
post #6 of 34 Old 05-28-2015, 07:57 AM Thread Starter
That's great guys. Thanks so much for the information.
I am going to look at a dual shaft later today and wanted to be sure it would work.
VT JD is offline
post #7 of 34 Old 05-28-2015, 09:27 AM
Likes (Received): 303
You may have to do some work to get the belt cover to fit with the new engine. The camshaft output shaft may get in the way. Is your model a JD 828 "D"? That's an Ariens built machine so may have some options for a different belt cover (Ariens made some dual shafted blowers, with different belt covers). It may fit up nice, I'm just trying to picture it. Maybe the dimensions will be such that the cam output shaft fits outside the original belt cover (assuming the pulley is removed).
You could take your belt cover with you and mock it up to check fit. You don't need the outside part of the shaft, so you could snip it off flush with the block too.
post #8 of 34 Old 05-28-2015, 08:09 PM Thread Starter
jtclays,
It is a JD 828D which I believe was made by Ariens for Deere.
I have seen the type of belt guard you referred to with the allowance in the belt cover to accommodate a second shaft.
I may have to come up with something if the original belt cover won't fit.
VT JD is offline
post #9 of 34 Old 05-28-2015, 10:00 PM
Thanks (Received): 48
The cam PTO also turns backwards.
OP if there are any clearance issues due to the second shaft it's a simple job to simply swap the cam and rear sump cover over from the old engine as long as you're using an 8 - 11hp flathead/L-head Tecumseh of a similar vintage. Generally speaking the cam and cover survive an engine failure, although I have occasionally seen them suffer catastrophic failure.
94EG8 is offline
Likes Grunt liked this post
post #10 of 34 Old 05-30-2015, 08:43 AM Thread Starter
94EG8,
That would be a good option if I run into clearance issues. Everything is in good shape on the old 8hp other than the connecting rod, which is on backorder at all the suppliers I have contacted. No damage to the cam, piston, block or sump cover.
I wondered if the Tec 8 and Tec 10 had interchangeable engine parts but you have answered that question.
Thanks a lot.
Still waiting to hear from the guy with the 10hp for sale. Seems he has gone into hiding.
VT JD is offline
