Ya it has a HEMI on it. - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 10-15-2015, 06:49 AM Thread Starter
Likes (Received): 58
Talking Ya it has a HEMI on it.
Picked this up on the side of the road a couple years ago. Figured if I could not fix it the scrap was worth a good bit as it is heavy and mostly steel.
Yes this was the condition of the engine shroud missing the carb and maybe a few other parts too. the engine did turn over and since the head was loose I peeked in side and the valves looked to be OK.
I have a friend who makes a living repairing small engines lawn mowers lawn tractors and snow blowers. I call him and ask about the missing parts, he tells me he has none and TEC. has folded so most of the scrap engines he gets is to full fill his needs best to shop for a used engine.
I put this blower on the far back burner watching and waiting for parts to repair it. Finally this spring I decided parts were not to be had so just invest in a new motor and for the value it was going to be a Harbor Freight Predator engine. The first motor I bought I decided to put on my log splitter and it really worked great on that application.
Went back and got another one two weeks later for the snow blower, this one the Hemi head version.
Cleared off the old engine matched up the crank shafts to see if stock belts would work.
Had to file the slag out of the mounting bolt holes so the 3/8 inch bolts would slide in freely. But that is all that was required to get it set properly on the deck. I also decided to install new belts so I would not have to do so at 30 below zero.
Note the cast alum valve cover the tell tale sign it is indeed the hemi.
I did have to lower the chute rotation crank to clear the valve cover too about 5 inches. I feel it is to low so will buy a universal joint and weld in place to reroute the crank and still clear the valve cover. and raise it up to a more user friendly position.
Got the chute off and drilled the impeller for the rubber clearance kit I am going to install.
I kept worrying about the tires as they are all weather checked and cracked. Bought 2 new ones yesterday to install on it.
Al
alleyyooper is offline
Likes 43128 liked this post
post #2 of 17 Old 10-15-2015, 07:34 AM
Likes (Received): 483
Did you get X-TRACKS or SNOW-HOG tires for it?
Those are the best 2 that you can get to use it with no chains on the tires.
post #3 of 17 Old 10-15-2015, 07:57 AM Thread Starter
Talking
For small roto tillers I believe. Minus the rims too
Al
post #4 of 17 Old 10-15-2015, 09:14 AM
My understanding is that they do not work that good on snow, I have seen them installed on a few honda snowblowers and there is were I read the negative feed back.
If you loose traction you may have to add chains to them.
X-TRAC are the best to my knowledge.
post #5 of 17 Old 10-15-2015, 01:45 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Nice job.
post #6 of 17 Old 10-16-2015, 07:45 AM Thread Starter
Talking
I don't think the tires will be a problem these machine was built when they still used real steel and not recycled beer cans so is heavy.
If there is a problem I can stud the tires and never worry about loose chains or slipping chains.
Woody's Tire and Boot Studs. Grip-It Screws are easy to install
Maxigrip Ice Studs HM11 - Tire Studs - Snow Studs | Maxigripstore
I have had good luck with Woodies in my ATV and the snow mobile too, a Local Michigan company.
Al
post #7 of 17 Old 11-04-2015, 09:31 PM Thread Starter
Talking
Finally did all the finishingtouches Tuesday morning. Now I know we won't get any snow this winter.
I had these 3/8 drive impact U joints in my tool box never being used in 20 some years. Well they are being used now on the chute crank rod.
Got the new tires on and aired to 7 PSI.
The before crack of the impeller in the houseing.
Closed the gap up some
Al
post #8 of 17 Old 11-05-2015, 06:48 AM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Old MTD's were good machines, I had a 640F from the mid nineties and it served me well for almost 20 years and still ran well when I sold it.
Nice job, good luck with it!
Cardo111 is offline
post #9 of 17 Old 11-05-2015, 02:18 PM
Thanks (Received): 21
Likes (Received): 52
Im confused about the "Hemi" reference. Its an overhead valve engine. Has nothing to do whether its a hemispherical combustion chamber or not
NJHonda is offline
post #10 of 17 Old 11-05-2015, 02:33 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
The Harbor Freight 212 cc Honda clone comes in a few variants.
https://www.ombwarehouse.com/Perform...c-Racing-Parts
dbert is offline
