New member with old Toro 724, auger belt too loose? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 10-26-2015, 09:04 PM Thread Starter
Hi all,
Name is Sam and I'm a new member. Thank you for having such good info on this forum. It's been very helpful with me swapping over the old Tecumseh on a '79 Toro 724 to a Predator 212CC. Ran into a problem with the auger belt that I didn't seem to have with the old setup and wondering if anyone has had the same:
My auger belt is EXTREMELY loose.. like, so loose that I don't think adjusting it at the clevis would help, as the opposite side of the arm the tensioner pully is mounted on is hitting the frame of the snowblower when fully engaged as it is. The way it is now, it just barely engages the belt and starts the drum turning(lots of slack and slapping against the little belt guide bar).. think if I was actually running it through wet snow it would start slipping.
Has anyone here that has done this repower experienced this? Could it be that my auger belt is just plain worn beyond use? Doesn't seem to me that this would be the case as it was okay with the old h70 on it, but to be honest, I didn't even look at the belt tension before I pulled off the belt and pully.
Any suggestions on what I might have missed?
Thanks in advance for any help/advice,
Sam.
SpAmSoNiTe is offline
post #2 of 9 Old 10-26-2015, 09:28 PM
Thanks (Given): 33
Thanks (Received): 14
Likes (Given): 21
Likes (Received): 19
Hi Sam and welcome to the group. You are right to say there's a lot of good info on this site.
As for your belt would a shorter one, say a size smaller, be the simplest way to 'fix' the problem?
BullFrog is offline
Thanks SpAmSoNiTe thanked for this post
post #3 of 9 Old 10-26-2015, 09:40 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Welcome to the forum Sam
If the height from the engines base to the crankshaft center line is shorter for the predator you need a shorter belt. That or you could add a couple washers under the engine to lift it up and tighten the belt that way.
Likes gsnod liked this post
post #4 of 9 Old 10-27-2015, 12:03 AM
Thanks (Given): 66
Thanks (Received): 19
Likes (Given): 139
Likes (Received): 28
Yep, sometimes when we repower with a Predator, the shaft is either too high or too low, requiring a different belt. I get most of my belts from NAPA, although Tractor Supply also has them. Take the old belt with you and get someting about an inch shorter and try it out. As long as you don't run it, NAPA will take it back if you don't know the size and buy several sizes.
gsnod is offline
post #5 of 9 Old 10-27-2015, 12:22 AM
i had the same issue with my 824(same machine with a slightly bigger engine). turns out the predators crank sits lower them the tecumseh crankshaft
post #6 of 9 Old 10-27-2015, 05:35 AM
Most blowers have a slit in the pulley that tightens the belt. You can adjust it that way in addition to adjusting the linkage between the frame and the handle bars.
Also make sure you put the pulleys on correctly. Generally the drive wheel pulley is a little smaller than the auger pulley.
post #7 of 9 Old 10-27-2015, 05:57 AM
Thanks (Received): 238
Likes (Received): 608
Welcome to SBF. Glad to have you join us here.
post #8 of 9 Old 10-27-2015, 08:30 AM Thread Starter
Thanks for the replies and welcomes all...
I was wondering if that were the case with the Predator shaft being in a slightly different location.. I'm going to pick up another belt to try and correct my issue today. Picked this old guy up in the summer last year for $35 running(ish), and after using it this past nasty winter, decided I will NEVER go back to shoveling my approx. 100ft. driveway again!(neighbor used to plow us out until the frame on his old truck broke).
~Sam.
post #9 of 9 Old 10-27-2015, 02:17 PM
Thanks (Received): 112
Likes (Received): 298
~Sam.
Hmm, why doesn't your neighbour get his truck fixed?? That would REALLY make it easier
skutflut is offline
