Motor replacement - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-16-2015, 12:19 PM Thread Starter
Motor replacement
So i have had this jewel for a few years. And the motor has been going down hill so its time for an upgrade. I have searched the forum trying to determine the exact year from other post with no luck. Can anyone out there steer me in the right direction for a motor replacement? Thanks!
ID:	63122   Click image for larger version
ID:	63130   Click image for larger version
ID:	63138   Click image for larger version
ID:	63146   Click image for larger version
Sharpie is offline
post #2 of 14 Old 11-16-2015, 12:47 PM
Thanks (Received): 7
Likes (Given): 18
Likes (Received): 8
Welcome to the forum Sharpie!
I think you have a late seventies model, at least from the 924000 series. You should have look at Scot's Snowblower & Tractor Pages as there is a picture of a 1979 model that looks very much like your blower.
Many folks have had great luck re-powering using Harbor Freight Predator engines, so may be worth checking out as well.
2001 Ariens 824(932101)
PolarNorth is offline
Likes Grunt liked this post
post #3 of 14 Old 11-16-2015, 02:14 PM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3366
Likes (Received): 683
Sharpie.
As PolarNorth stated, "many" people have re-powered their older machines with the 5hp Predator motor from Harbor Freight if your in the USA or Princess Auto if in Canada. Below is a link to the re-powering sub forum.
Re-Powering - Snowblower Forum : Snow Blower Forums
post #4 of 14 Old 11-16-2015, 05:39 PM Thread Starter
I had seen people discussing the engines from harbor freight. Will i see much difference going from the 7 to the 5hp? And how much modification if any is required?
Sharpie is offline
post #5 of 14 Old 11-16-2015, 05:52 PM
Likes (Received): 483
The predator engine is a 6.5hp (not a 5hp). I did a repower on a 10000 series 724 and you can clearly see the difference in starting and performance of the Predator engine.
If your engine is a single shaft it will be straight forward except for possible the chute turning rod and the engine mounting studs.
If your engine is a dual shaft, it won't be straigt forward at all.
post #6 of 14 Old 11-16-2015, 06:40 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Your Machine has a 1" Crankshaft. The Predator has 3/4" which you will have to sleeve to use the original Ariens Pulley. You should let us know Your Location, someone may have a replacement Enginw available Locally.
Jackmels is offline
post #7 of 14 Old 11-16-2015, 08:37 PM Thread Starter
You guys have been a load of help so far. Thanks for taking the time to help. I am located in eastern iowa close to Davenport.
Sharpie is offline
post #8 of 14 Old 11-16-2015, 09:36 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Please add your location to your profile. Thanks
Did you want to stick with a Tecumseh replacement or are you open to the Predator ?? http://www.harborfreight.com/65-hp-2...epa-69730.html
If you go Predator you would likely feel the 6.5 hp outperforms the 7 hp Tec even on the Tec's best day. For $100 (w/coupon) - $125 (without) plus some small parts I think it's well worth it.
If you want to keep it original that's just a personal choice and nothing wrong with that.
Going with the Predator you are limited to no electric start and no engine supported lighting or hand warmers if they are a consideration.
You'd need a 1" X 3/4" bore reducer like : 3/4" X 1" BORE REDUCER | eBay
post #9 of 14 Old 11-16-2015, 10:17 PM
Not nescessarily, I think that there are kits available or at least a charge coil, like the one on the link.
Charging Coil for the Predator 212cc 6.5 Hp Engine : Monster Scooter Parts
post #10 of 14 Old 11-17-2015, 01:58 AM Thread Starter
For the price i will be willing to go with the pred motor. Will do some checking to see if mine is a single shaft and go from there. Thanks for all the help!
Sharpie is offline
