Predator 8hp, need to find 1" ID pulleys - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 12-04-2015, 09:20 AM Thread Starter
I have a agway (Murray) 27inch blower that had a Tecumseh 8hp on it and it threw a rod so I want to put a predator on it. The predator engine has a 1 inch shaft and the old Tecumseh has a 3/4 shaft so I need to find some pulleys for a 1 inch shaft. The old one had 2 split pulleys on it. Does anyone know where to get some pulleys for a 1inch shaft or know of a blower with that pulley that I can order
Mike101010 is offline
post #2 of 26 Old 12-04-2015, 09:29 AM
Likes (Received): 1384
Tractor supply, or your local friendly neighborhood hardware store.
Thanks bwdbrn1 thanked for this post
post #3 of 26 Old 12-04-2015, 09:34 AM Thread Starter
I'm going to look there but i was hoping to get one of the oem ones from a bigger blower. The original ones are pretty small
post #4 of 26 Old 12-04-2015, 09:36 AM
Iwould not go putting bigger on there. your likely going to smoke the gear case doing that 1.
post #5 of 26 Old 12-04-2015, 09:55 AM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
Welcome to the forum Mike
You could take them to a machine shop and have them drilled/bored out to fit.
Spend some time tracking down OEM ones that fit a 1" shaft. Just a matter of looking them up one by one.
MFG supply Snowmobile Parts, Go Kart Parts, Lawnmower Parts, ATV Parts, and more | MFG Supply
OMB Whse. https://www.ombwarehouse.com/All-Oth...owblower-Parts
Or go with the 6.5HP Predator that has a 3/4" shaft
6.5 HP (212cc) OHV Horizontal Shaft Gas Engine EPA
Doubt you'd notice a difference with power as the 6.5 is a common replacement for a slightly bigger engine with good results.
post #6 of 26 Old 12-04-2015, 10:10 AM Thread Starter
Thanks for the info I was going to go with the 6.5 but Leary about it . It's going to be used in northern vt that gets a lot of deep snow and snow shoveled from a roof so I'm I dunno if it would be a good choice for me seems like the majority say 26inch blower is max for the 6.5 and is really working it in big snow what are your thoughts on that
post #7 of 26 Old 12-04-2015, 10:38 AM
Thanks (Given): 592
Likes (Given): 4377
I think you'd be ok with the 6.5 as no one who's put one on a blower has ever posted a complaint. It should replace the 8 horse and give you nearly if not the same performance due to it's improved design (overhead valve). I think it'd work as well on your 27" as the 8hp Tec did.
My machine, I'd go with the 8 horse and try to find a 1" pulley/sheve that's a tad bigger in diameter to boost the impeller speed a little to help it toss a bit further. But get the same diameter as stock for the transmission one. I like having a big engine but that's not because of need, just a "Tim Taylor" thing.
post #8 of 26 Old 12-04-2015, 11:41 AM
Likes (Given): 1891
Likes (Received): 670
hello mike, welcome to SBF!! I would go with the 8hp motor
post #9 of 26 Old 12-04-2015, 11:50 AM Thread Starter
I have the tool man mentality to bigger is always better. I'm going to measure the pulleys when I get home and see what I can come up with for sizes I would need
post #10 of 26 Old 12-04-2015, 11:55 AM
Likes (Received): 58
I just did a 212cc 6.5hp predator Hemi version engine install on a little 24 inch MTD blower. I also did a impeller up grade and I was really impressed when we got 10.5 inches of snow a couple weeks ago with 2 inches of slush under the snow in the driveway. I was throwing the snow a good 30 feet even the slush was going that far. I can't see 3 inches more in width requiring more than that 6.5hp.
Al
alleyyooper is offline
Likes bad69cat, Eyeboltman liked this post
