Ariens 524 Engine Replacement - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-11-2015, 06:41 AM Thread Starter
Hello. Received an Ariens 524 with a blown motor. Took the motor apart to find a broken camshaft and a bent intake valve. The crank case is also broken where the camshaft sits in the seat.
The engine model is HSSK50 67244R. This engine has the camshaft PTO.
As everyone knows - Tecumseh's are pretty hard to come by these days. Looking for one of a couple options to get this thing running...
1 - Source for replacement HSSK50
2 - Alternative engine - two shaft
3 - Source for replacement crankcase, camshaft, valves
Would appreciate any expertise that the group has developed over time since Tecumseh closed their doors. I'm hoping that by now there are people who have experimented and found working alternatives for those of us with these engines.
TIA..
-Mike-
[email protected]
Mike9369 is offline
post #2 of 6 Old 12-11-2015, 06:57 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Hopefully others can contribute more but as far as I know there are 3 things people do in this situation:
1) Buy a Chinese clone motor like the "Predator" sold at harbor freight and mod it to have an extended camshaft. Requires a *lot* of machining, welding, and fabrication and might require a Tecumseh camshaft as a donor?
2) Buy another Tecumseh motor and swap your crankcase cover and cam onto it. That's obviously not an option in your case.
3) Find another compatible Tecumseh motor.
I'm a bit surprised you said these motors are hard to come by... there are generally a bunch of them available on Craigslist. For example this one: https://syracuse.craigslist.org/grd/5313159832.html
There is one "trick" to finding Tec 2-shaft motors on Craigslist: sometimes they come attached to snowblowers! With some research (or just by going to look at the thing) you can determine what makes & models of snowblowers came with that type of engine. Then just look around C'list for a snowblower that's cheap because it's rusted or has mechanical problems, buy it, and use the motor.
ELaw is offline
post #3 of 6 Old 12-11-2015, 07:53 AM Thread Starter
Thanks for the reply. Geeze - I was so focused on a new engine that I hadn't thought about looking for a used engine.
This might be the question from ****, but any ideas at all on Tecumseh models that are compatible with the HSSK50 in order to make this as close to a bolt on replacement as possible?
It looks to me that the HS50 might work, and maybe some others, but I don't understand Tecumseh's model number system at all.
Mike9369 is offline
post #4 of 6 Old 12-11-2015, 08:06 AM
Thanks (Given): 11
Likes (Given): 19
Well the first question you have to ask yourself is do you want to stick with 5 HP or take the Tim Taylor "more power" approach?
Again there are others here more expert than I, but I think in general the Tecumseh engines you'd be looking at fall into two categories: "small frame" as indicated by the second letter in the model being an "s" (the first "h" means horizontal shaft) and "medium frame" as indicated by the second letter in the model being an "m". I think the small-frame engines are 7 HP and below, the mediums are 8 and up. So you should easily be able to upgrade to a 6 or 7 HP engine if you want to.
"SK" in the model means "snow king". Generally I think that means an "sk" engine will have the metal box covering the carb and linkages, and no air cleaner. An engine without "sk" probably would not have the box and would have an air cleaner. The latter "problem" could of course be easily fixed by removing the air cleaner, but I'm not sure what models your heater box would bolt onto.
I do know there are differences in the mufflers used between different horsepower levels, and maybe variations over time too.
I *think* that in terms of mounting, you could replace your small-frame engine with another small-frame engine, even one of higher horsepower. To go to a medium-frame engine you'd need to redo the engine's mounting... which takes a little work, but really is not too difficult.
In general I'd say you can base a lot on appearance. If the replacement motor looks pretty much like yours (the double output shafts being the most important factor), it should work. You might have to swap over a few parts to account for minor differences like the throttle control being on the engine vs. the handlebars (for example).
Oh one other thing you DO have to watch out for: crankshafts come in different diameters (3/4", 7/8", and 1" being most common on snowblowers), and I think some have tapped holes in the end so the pulley can be held on by a bolt, whereas others do not.
ELaw is offline
post #5 of 6 Old 12-11-2015, 10:48 AM
Likes (Received): 36
check the bolt pattern and the shaft height. then check small engine warehouse. you can find good deals on new engines there, if that's how you decide to go. they may have a tec.. that will bolt right on. I picked up (locally)a new briggs 15000 series 11.5 lbs torque snow max, that had the same bolt pattern and shaft height, just had to use longer bolts to mount as the original studs were to short. was very easy, probably the easiest part of my restore.
ctdave is offline
post #6 of 6 Old 12-11-2015, 11:03 AM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Welcome to the forum Mike
to "Re-Powering"
